Latest post Fri, May 23 2008 8:51 PM by Dom Q. Silverio. 8 replies.
Page 1 of 1 (9 items)
  • Thu, May 22 2008 1:57 AM
    • Gerrit
    • Posts 56
    • Points 630
    Working with HDV - Mojo monitoring
    Having read the handy Working With HDV pdf that can be found here, I just wanted to clarify about monitoring - client will be working on Media Composer 2.8 software with Mojo SDI, having shot HDV 1080i50. The plan is to ingest HDV into HDV project as recommended. The pdf then states in order to monitor edit via Mojo, one must switch Project Format to 25i.
    My question is, what happens when you continue editing the HDV material within project format set to 25i? Are you still working within the HDV domain with DNxHD-120TR used for rendering, but now wit the added option of an SD downconvert via Mojo?
    My understanding is that as soon as any rendering needs doing, Avid will make use of the DNxHD120TR codec, but will this codec show up as a rendering option in Media Creation within 25i project, or only within 1080i50 HDV format?
    I don't want a workflow where client has to work on computer monitors and switch back and forth to toggle between editing and watching their edit on a broadcast monitor. Obviously when something new needs capturing they will have to switch back to HDV format.
    Can someone clarify please?
  • Fri, May 23 2008 3:17 PM In reply to
    • sixencar
    • Joined on Tue, May 13 2008
    • Posts 3
    • Points 35
    Re: Working with HDV - Mojo monitoring
     I would like to know it also.....
    Eric
  • Fri, May 23 2008 3:27 PM In reply to
    Yep you will be forced to render at SD res.
    As a workaround you can rerender the timeline after you have reached pix loc.
  • Fri, May 23 2008 3:28 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,644
    • Points 160,595
      Moderator: MCA Mac
    When you change your format to SD for monitoring, you will also be changing your Media Creation settings to SD. So, any renders you do will be in SD.
    One great feature in the upcoming release is the ability, when you are done with your cut, to change the format back to HDV, tell the system to un-render the entire timeline and then you can do a quick render in to out to get your precomputes back up to HD.
  • Fri, May 23 2008 6:00 PM In reply to
    • Laptopeditor
    • Joined on Tue, Feb 27 2007
    • Montreal, Canada
    • Posts 765
    • Points 9,425
    BLKDOG:
     ....This is a great feature ! HDV is the bane of our existence. How do you tell the system to unrender all the renders its done in SD however ?
    Upgraded to Media Composer from Avid Xpress Pro and now at MC 3.0. Also added Avid Studio Toolkit 5.7 running on.....HP Compaq nw 9440 Laptop PC w/2 x... [view my complete system specs]
  • Fri, May 23 2008 6:05 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,644
    • Points 160,595
      Moderator: MCA Mac
    It's not that smart. It just unrenders the timeline or between in and out points.
  • Fri, May 23 2008 6:11 PM In reply to
    Laptopeditor:
    For the current release (since it seems to have been fixed in v3)...
    drop the sequence in a new empty bin.
    Open Set Bin Display in the bin's fast menu
    Check 'Rendered Effects'
    This will reveal all the render media related to this suquence in the bin. You can sort it from here.
  • Fri, May 23 2008 8:44 PM In reply to
    • dor
    • Israel
    • Posts 179
    • Points 2,245
     Hi
    I have found a bug in MC (from ver 2.5) and this might help you!
    The bug is when you map a keyborad shourcut for "render In/Out", to any  SHFT KEY, it will render ALL EFFECTS AGAIN!
    By default it should render only unrendered effects (and it does if you map the render command to a non SHIFT KEY).
    I use this a lot when I go from OFFLINE to ONLINE. It force the sequence to be re render.
    I think it can work in this case too.
    MC 3.0 + MOJO SDI. Q9450+4GB RAM. 8800GT. XP PRO SP3 [view my complete system specs]
  • Fri, May 23 2008 8:51 PM In reply to
    It is not a bug but an actual documented feature (search the help for RERENDERING). The steps I indicated allows you to sort.
