Latest post Wed, May 21 2008 10:56 PM by DIESELE. 7 replies.
  • Wed, May 21 2008 8:55 PM
    PAN ZOOM, AXP to MC and system specs assistance.
    Hey everyone,
    One of my clients would like to upgrade to Media Composer and they are wondering if the systems performance will improve.
    The system is a dual xeon 3.06, 2gig ram, FX1100 and scsi media drives.
    All the work is on DV25 - when applying a PANZOOM effect before rendering the system becomes unstable and crashes often - AVID XPRO 5.7 is version!
    Will 2 more gigs of RAM installed + VISTA + New Media Composer will this help their situation or run XP(SP2) with 2 more gigs of ram only!
    Cheers
    Best Regards,
    Julian Ridi
  • Wed, May 21 2008 10:12 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 355
    • Points 4,255
    Re: PAN ZOOM, AXP to MC and system specs assistance.
    I do not believe Vista s approved with 2.8 versions of the software. I would suggest remaining with Win XP.
    What is the exact system? It sounds like an HP XW8000, but we can help more if we know exactly what system it is.
    MCA 2.8.3 on Dell 490 • 4GB Ram • Quadro FX3500 Driver 6.14.10.9185 • Avid rs146 x 2 striped as one • 2 internal 500 GB SATA drives. Edit monitor: Sony... [view my complete system specs]
    A gentle answer turns away wrath, but a harsh word stirs up anger. (Proverbs 15:1 NIV)
  • Wed, May 21 2008 10:20 PM In reply to
    It's a clone of the HP XW8000
    Intel 3.06 CPUs, intel SE7505VB2 Mobo, 2gig Crucial ram, Nvidia FX1100 APG, ATTO UL4D, Maxtor 40 gig (system), WD 320 gig x 2, Seagate 146gig SCSI x 2, SBlive card, 520 Vantec PSU. Antec Server Case
    Avid Xpro 5.7 with non-SDI Mojo.
    Anythiny else??
    Julian Ridi
  • Wed, May 21 2008 10:24 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 316
    • Points 3,480
    More tools and a better interface, better perfomance with 1:1 media, but this may not be relevant for Your client; Pan&Zoom is a memory eater, on MC 2.8.3 it runs in a low quality mode until rendering, which helps, however several unrendered P&Z effects will still be a be challenge for the system; 2 gbs of additional ram will help only if You run the Avid memory patch found in the installer disk, there are quite a few posts in the forums regarding this; as for Vista, I would not go for it: it's not supported until the MC 3 release, moreover, it's much heavier and resources hungry than XP, personally I'll consider switching to Vista whenever Avid will support the 64 bit Vista version, as of today I'd rather buying a MacIntosh than running Vista. Hope this helps.
    MC 3.0.5/Mojo, Vista 64 biz, Gigabyte GA-EP45T-EXTREME, Intel Q9450, 8 GB ram, Pyro 64, Quadro FX 1700, 2 x 1TB drives (raid 0) for mediafiles + G4 MacBook... [view my complete system specs]
    peace luca
  • Wed, May 21 2008 10:32 PM In reply to
    Thanks everyone - The system acutally requires a re-format and re-install of everything.
    I'll get the quote out for the ram and see what they think - they are going up to MC regardless
    Let's hope more ram helps them out!
    Cheers
    Julian
  • Wed, May 21 2008 10:35 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 316
    • Points 3,480
    AVIDEDTR@mac.com:
    ... Let's hope more ram helps them out!
    Cheers
    Julian
    It certainly will, cheers to You too
    peace luca
  • Wed, May 21 2008 10:49 PM In reply to
    "Let's hope more ram helps them out!"
    Remember to utilize the /3GB switch in the boot.ini to make the additional RAM available.  Refer to the Readme file for details.
  • Wed, May 21 2008 10:56 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 106
    • Points 1,260
    That is a *** of a plugin to work with , but gives good results when not outputting black!!!  My tips:
    • Work in uncompressed TIFF format - then you knwo the exact RAW filesize.  You wint know this with compressed files as Avid has to uncompress them to zooom them about.
    • Keep files to about 4Mb max
    • Work to max picture size of about 1500 pixels (on any side).  If you know you will be pushing it to 3 x zoom in then risk more - if not, there is no point.
    • Render it as son as you are happy with your move.
    • Use Gausian render setting if you have many 'too thin for TV' lines in your source files - minimises the ailiasing/judder
    These are only my usual trial and error learn the hard way comments :) but had few problems this time round using those settings on a timeline with many uses of that effect.
    I'll be trying Boris CC's similar plugin next and hope it allows much needed rotate and aspect ratio corrections.
    D
    MC 3, XP SP2, Asus P5K-E Mobo, Quad Core 2.7Ghz CPU (3.0 Ghz if I'm up against it!), 4Gb 800Mhz RAM Dual channel, 4 x 500Gb SATA Stripe O pairs, Quadro FX 1500 GFX, Soundblaster Audigy.  Approved Avid HP 8240 Notebook. Original DIY PC: Shuttle SN85, AMD 3200, 1Gig Ram, Quadro 980, on board sound, on board firewire, 2 x SATA + WD ext HDD - could that be less 'compatible? Never hiccuped once! :-)
