Latest post Fri, May 23 2008 9:02 PM by Doc Avid. 3 replies.
  • Wed, May 21 2008 7:16 PM
    • dingo1
    • Grinnell
    • Posts 156
    • Points 1,915
    sending to a non avid automation system
    I'll post this around but my basic problem is I have a lanshare post facility on interplay that pulls from a unity system on media manager (news) that also sends to airspeeds for news playout. All well and good, but we play our programming (non news) out through grass valley profiles (and K2) controlled by a harris automation system. At present the only way to send spots from post to the grass/harris system is to dump it to tape then dig into the automation system. So i want a "send to" solution from avid to harris....anyone doing anything like this? Curious minds want to know Cheers gregg G
    2 PC NCA 6.8 on lanshare 1Mac MCA 2.8 on lanshare 1 Symphony Nitris classic 3.0 Passel full of PC express pros on Dells 1 express pro on macbook pro [view my complete system specs]
  • Wed, May 21 2008 8:30 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,531
    • Points 66,070
    Re: sending to a non avid automation system
     My engineer tells me that if you capture to Avid Agility, you can then flip the file for FTP through an intra-net to your Harris automation system, IF  the Harris will recognize an Avid formatted file.
  • Thu, May 22 2008 7:05 PM In reply to
    • dingo1
    • Grinnell
    • Posts 156
    • Points 1,915
    Thanks Larry, didn't know about "agility". I'll check into it, Cheers Gregg G
  • Fri, May 23 2008 9:02 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,122
    • Points 23,450
    Agility is an ANYSTREAM product, not an Avid one.
    Telestream can also do this via a Flip Factory,  using quicktime references as sources,  which makes for a nice easy send to file.   Hits the drop, Flip grabs it, collects the media referenced, and turns it into the file you need.
    JDS
    Just about all of them, And a '06 Scion xB [view my complete system specs]
