Latest post Thu, May 29 2008 3:51 PM by CineRover. 5 replies.
Page 1 of 1 (6 items)
  • Wed, May 21 2008 3:41 PM
    • CineRover
    • Posts 9
    • Points 105
    "Unsaturated" image quality capturing 24p from DVX100A.
    Hi helpers,
    Here are my specs
    Shot on: DVX100A in 24p mode
    Editing on: Avid 5.7.2, Dual 2Ghz G5
    Capturing from: DVX100A via firewire
    My story:  Capturing at DV25 411 gives me a "washed out" image, lacking needed saturation and contrast. This is noticed both on the computer and my monitor.  This occurs in both a 24PNTSC or a 30iNTSC project. I'm capturing via firewire through a mojo, but get basically the same results coming in component or s-video (with a modest improvement). Also happens with higher res settings.
    I searched for this issue on the boards but couldn't find an answer. Anyone know what's up? Thanks in advance for your help.
    Dan
  • Wed, May 21 2008 6:18 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,696
    • Points 161,335
      Moderator: MCA Mac
    Re: "Unsaturated" image quality capturing 24p from DVX100A.
    This isn't really an Avid thing. I think it may be a DV thing.
    Unless you are saying that the footage looks better captured at another res, I am going to guess there wasn't enough light on what you shot in DV. DV requires a butt-load of light to look good at any normal aperture settings.
  • Wed, May 21 2008 6:44 PM In reply to
    • CineRover
    • Posts 9
    • Points 105
    Thanks for the reply BLKDOG,
    The problem doesn't appear to be low-light as I'm getting this throughout a wide variety of shots (interior interviews and exterior broll) with various lighting conditions (butt-load and non butt-load amounts)
    Though I know it's not the best guage, the onboard monitor of the camera shows a much richer image.
    Importing into FCP seems to make the problem go away.  I noticed the DVX100A wasn't on Avids list of compatable decks.  Could this be the problem
  • Wed, May 21 2008 7:03 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,696
    • Points 161,335
      Moderator: MCA Mac
    Ok. If you import to Final Cut and get a different picture, than something else is going on.
    I just captured 4 hours of DV over SDI and the picture is pretty true to the original. Have you tired capturing in the Avid in a different  res?
  • Wed, May 21 2008 8:12 PM In reply to
    • CineRover
    • Posts 9
    • Points 105
    Looking at the other options, it seems as though importing via S-Video or composite, the problem goes away. Changing the resolution (tried 1:1 MXF) doesn't have an effect.  It only happens via FW
    I guess I'll do a test shooting some footage at 30i and see if something's up with the 24p communication between camera and avid.
    thanks,
    d
  • Thu, May 29 2008 3:51 PM In reply to
    • CineRover
    • Posts 9
    • Points 105
    Just updating my issue. After a bunch of tests, I'm more inclined to think that it was a shooting issue rather than an avid thing. Yes, FCP seemed to handle the footage a bit better, but from what i can tell, I had some poor settings on my 24p "scene file" on the DVX100A.  Took out too much chroma perhaps?  In any case, thanks for the help BLKDOG.
