Latest post Wed, May 21 2008 7:00 PM by slabross. 2 replies.
  • Wed, May 21 2008 12:54 AM
    • Headbone
    • Posts 9
    • Points 135
    Nitris forgetting Media Folders
    Hi there,
    We are having an issue with our DS Nitris, every time we boot it up it's losing it's media folders, and we have to re-configure the storages every time. Is there any solutions to this? Thanks!
  • Wed, May 21 2008 1:08 AM In reply to
    Re: Nitris forgetting Media Folders
    Um, we're gonna need a little help here.  What kind of storage?  Local?  Shared?  When did this start?  Any changes to the system recently?
  • Wed, May 21 2008 7:00 PM In reply to
    • slabross
    • Montreal
    • Posts 201
    • Points 1,865
    Avid DS persists its media storages from a server.ummd table that includes the media files list (index) and the storages configuration.
    In your case, it seems that this list is damaged and thus cannot be updated (or keep its settings).
    Check in the Windows Computer Management console, under Services, if the Avid Media Indexer is started.  And if you can stop and restart the service fully.
    If it won't stop (loop endlessly or hang), the server.ummd is corrupted and must be deleted (from C:\Program Files\Avid\Services\DSSystem).  Note that you again will lose the storages settings until the Avid Media Indexer can work normally and build a clean server.ummd table content.
    For more details, consult the application DVD content under Drivers and Utilities and look for the HTML Troubleshooting section in the workstation that match your setup.  The same information is also available online from the Avid DS Support center.
    Sylvain Labrosse
    Team Lead for Avid DS
    WW Mission Critical Services
    Global Customer Support & Operations
    Avid Technology Inc.
