Latest post Wed, May 21 2008 10:07 AM by admo33. 5 replies.
Page 1 of 1 (6 items)
  • Tue, May 20 2008 12:01 PM
    • admo33
    • Joined on Wed, Apr 9 2008
    • london
    • Posts 14
    • Points 190
    Add a new video track ON TOP of the previous video tracks
    Hi there,
    I have some troubles sometimes when I add a new video track on my timeline, it generally goes on top of the other tracks, but there are some times when it is randomly inserted in the middle of the tracks, or even at the bottom! Let's say I have 15 video tracks, when I add a new track, instead of going on top of the 15th track, it goes on top of the 9th....or sometimes at the very bottom.....Which forces me to manually lift up all my clips one by one in order to get a free video track on top....there must be a way to tell it to go on the top, and ON THE TOP ONLY!
    Any solutions to that very appreciated.
    Cheers
    AVID XPRESS PRO HD HPW workstation Dual Xeon 5.4 GHz Quadro FX 1500 MOJO SDI [view my complete system specs]
  • Tue, May 20 2008 12:05 PM In reply to
    Re: Add a new video track ON TOP of the previous video tracks
    It will always create the lowest unused track number. So if you have V1, V3 and V4, adding a track will give you V2.
    Other than that, you can CTRL-drag the vertical position of a track. If your settings have V4 placed under V3, that will mean that when you add the fourth V-track, it will appear below V3.
    There should be no need to drag clips between layers, you can move the tracks themselves.
    HTH.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Tue, May 20 2008 1:12 PM In reply to
    Ctrl Alt Y allows you to add a video track and select any track number you want.
    If you choose an existing tracks number, V1 for instance, you get the option to insert the track at that position. All the tracks above then resuffle their numbers.  Great for the reverse of what you are asking
  • Tue, May 20 2008 8:08 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 104
    • Points 1,250
    Where has that tip been all my life!  Brilliant!  Thx
    MC 3, XP SP2, Asus P5K-E Mobo, Quad Core 2.7Ghz CPU (3.0 Ghz if I'm up against it!), 4Gb 800Mhz RAM Dual channel, 4 x 500Gb SATA Stripe O pairs, Quadro FX 1500 GFX, Soundblaster Audigy.  Approved Avid HP 8240 Notebook. Original DIY PC: Shuttle SN85, AMD 3200, 1Gig Ram, Quadro 980, on board sound, on board firewire, 2 x SATA + WD ext HDD - could that be less 'compatible? Never hiccuped once! :-)
  • Tue, May 20 2008 8:14 PM In reply to
    No problem, Simmarly Ctrl Alt U does the same for audio tracks
  • Wed, May 21 2008 10:07 AM In reply to
    • admo33
    • london
    • Posts 14
    • Points 190
     Brilliant guys, thanx a lot!!!
