Latest post Tue, May 20 2008 11:03 PM by BILGAMI. 4 replies.
  • Tue, May 20 2008 4:17 AM
    • BILGAMI
    • cc tx
    • Posts 28
    • Points 370
    Color pass
     does axp have color pass?
    axp with mojo 5.7 windows xp pro 2.8hz 2gigs [view my complete system specs]
    bilgami www.bilgamivideo.biz
  • Tue, May 20 2008 3:56 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Re: Color pass
    If  you mean can Avid color correct your finished footage. Absolutely.
    Exactly what  do you mean by "Color Pass"?
  • Tue, May 20 2008 7:46 PM In reply to
    • BILGAMI
    • cc tx
    • Posts 28
    • Points 370
    Re: Color pass
     maybe im not using the correct term. but the effect i want is when, you the picture black and white but only the red from the roses are red and the rest is black and white.
  • Tue, May 20 2008 8:05 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Re: Color pass
    In xpress 'Pro you either need a 3rd party plug to do this  or, you can do what I did for years and use a two layer effect.
    On v1, place  your shot on V1 and make it black and white. Then put your "Rose" shot on V2 and place a chroma key effect on the layer. Select the red in the rose to key out. Once you have the rose keyed properly, just invert  the key.
  • Tue, May 20 2008 11:03 PM In reply to
    • BILGAMI
    • cc tx
    • Posts 28
    • Points 370
    Re: Color pass
    sounds simple enough, it sounds alot like the dmn transfer effect.
    thanx
