Latest post Tue, May 20 2008 8:09 PM by JL Streich. 5 replies.
Page 1 of 1 (6 items)
  • Tue, May 20 2008 3:15 AM
    • JL Streich
    • Joined on Mon, May 19 2008
    • Posts 2
    • Points 20
    Can you run Avid Express on XP Home OS?
    I've been told both ways - any advice?
  • Tue, May 20 2008 4:12 AM In reply to
    Re: Can you run Avid Express on XP Home OS?
    I would steer clear of XP Home, historically on occasion users will experience some sort of permissions issue with their user accounts that will cause a large number of problems with the Avid.  XP Pro provides a simple way to change those permissions, XP Home requires an OS install.
    Also, you could try a search here on the forums for horror stories related to XP Home.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Tue, May 20 2008 5:34 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,340
    • Points 38,445
    The worst part about Home is that everything can appear to be running normally, then out of the blue Avid will fall over with an access error.  Once it does that the only real fix is to reinstall Windows, then Avid, then anything else you need.
    Don't do it.
  • Tue, May 20 2008 8:06 AM In reply to
     So youre suggesting XP Pro then ??
    Peter
  • Tue, May 20 2008 8:28 AM In reply to
    • camoscato
    • Posts 4,528
    • Points 54,105
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Peterdubbingmixer:
    Hi Peter,
    The Xpress Pro System Requirements call for XP Professional.  As it says on the page, "If your system does not meet the minimum system specifications, it may not work."
    Can you run Xpress Pro on XP Home?  Probably, but there's no guarantee it will work.  Should you run Xpress Pro on XP Home?  No, because if you run into problems, it will be harder to solve them, as Kenton and jwrl have pointed out.
    good luck,
    Carl
  • Tue, May 20 2008 8:09 PM In reply to
    • JL Streich
    • Posts 2
    • Points 20
    Okay, my situation is I have a 5 year old Dell Dimension with a fairly fast processor & RAM - but I bought it with XP Home installed because I had no idea at the time Avid need XP Pro. How hard is it to replace the OS with XP Pro - assuming an upgrade for it is still available? Not that I have any $ to spare, but am I better off buying a new computer altogether to install Xpress on? BTW, thanks all for the answers.
