Latest post Tue, May 20 2008 6:53 PM by AndrewAction. 10 replies.
Page 1 of 1 (11 items)
  • Mon, May 19 2008 7:31 PM
    • JoeProcopio
    • New York City
    • Posts 304
    • Points 3,730
    8 ch .wav possible?
    is it possible to output an 8 channel .wav file out of the Symphony Nitris?  if not, is there any way to export it to another program to create the 8 ch wav?  we can't export broadcast .wavs yet can we?
    1-DS/SN Nitris 8.4 QFE 1/1.8.3 xw9300 10TB local 1-SN Nitris 1.8.3 xw8400 10TB local 1-SN Nitris 1.8.3 xw8200 10TB local 3-MCA 2.8.3 xw8200 2-MCA 2... [view my complete system specs]
    Joe Procopio Broadway Video AVID|DS Artist AVID Tech
  • Mon, May 19 2008 7:40 PM In reply to
    Re: 8 ch .wav possible?
    AFAIK, we cannot output a multitrack WAV. Michael P on one of these fora suggested that BWAV export is implemented in the forthcoming 3.x release. Not sure if that includes "direct out" multitrack exports.
    I think ProTools will allow you to output as a multitrack BWAV. You could do mono track-by-track exports from your Avid as well.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Mon, May 19 2008 8:11 PM In reply to
    • JoeProcopio
    • New York City
    • Posts 304
    • Points 3,730
    well aware of the mono outs...i'm gonna see if I can do it in the DS...thanks!
  • Mon, May 19 2008 10:32 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 232
    • Points 2,975
    You should be able to export a QuickTime Reference file with 8 channels. Open the reference file in QTPro and save as a self contained QT File.
    Bob
    -- Bob Russo Applications Editor at Avid Technology
  • Tue, May 20 2008 8:55 AM In reply to
    Bob, how? AFAIK, the Avid needs to be in Mono or Stereo Out mode to even be able to do a QT ref export with sound (which in itself is a drag). So how do you get 8 separate tracks to a QT Ref, without summing them? I'd love to proven wrong, though....!
  • Tue, May 20 2008 1:55 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 232
    • Points 2,975
    To export a self contained QuickTime the audio needs to be mixed down. But for a QT Reference file the option to mix down the audio can be turned off. The reference file will have 8 channels of audio.
    A QuickTime with 8 channels of audio can be imported into an Avid also.
    Bob
  • Tue, May 20 2008 2:39 PM In reply to
    Thanks, did not know that. Will give this a try, might come in useful!
  • Tue, May 20 2008 2:54 PM In reply to
    5.1 from Avid in a 6 track QT ref?
  • Tue, May 20 2008 4:06 PM In reply to
    • JoeProcopio
    • New York City
    • Posts 304
    • Points 3,730
    but can QT pro export an 8 Ch wav?
    I was able to do it in DS, very easily
  • Tue, May 20 2008 5:06 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 232
    • Points 2,975
    "Dolby 5.1” could mean any of a number of things, and the answer depends on which one you had in mind.
    In professional production, my guess is you're most likely referring to “Dolby-E”, which carries 5.1 plus a stereo mix on two digital audio channels.  If all these rules are obeyed, Dolby-E data can be preserved through Symphony Nitris Classic and cuts only editing of audio tracks.
    The audio channels must remain at unity gain, with no clip effects or automation gain and the master gain slider must also be at unity.  Direct out mix mode is recommended and of course, no effects can be applied. Even if running the Dolby hardware in 16 bit mode, it's still recommend to us 24-bit audio media files. The 24-bit format will allow running Dolby-E in 20-bit mode.  Monitoring with an outboard Dolby-E decoder on the AES outputs is recommended to ensure that everything is correct.
    If all the rules are followed and since the audio is not being recompressed and linking to the original clips it should retain the Dolby encoding.
    Having written all of this, I'm far from the expert on the subject and know just enough to be dangerous.
    Bob
  • Tue, May 20 2008 6:53 PM In reply to
    BobRusso:
    Dolby 5.1” edit  the answer depends on which one you had in mind.
    Protools.
    Next time I will take my tongue out of my cheek Bob. (Or at least make it more obvious.) Had just been playing with sending 6 stems in a 6 track bwf to an audio designer to see what we can get into and out of his system.
    Thanks for the thoughtfull reply though.
