Latest post Wed, Oct 15 2008 8:17 PM by Tashiquoi. 9 replies.
Page 1 of 1 (10 items)
  • Sun, May 18 2008 5:15 AM
    • miwos
    • Joined on Thu, Oct 4 2007
    • Posts 9
    • Points 145
    Media Composer on Macbook Pro 2.2 Ghz?
    Hello, I was wanting to purchase MC academic for my Macbook Pro 2.2 GHz intel core 2 duo. I am running osx v. 10.4.11, 2gb ram, qt 7.4.5(unfortunately I hear). I looked on the site and saw that this particular model of macbook pro (2.2 ghz) was not on the recommended list.
    Has anyone run this model of macbook pro with media composer academic? Will it run on this? I appreciate the help very much!
    Thank you!
  • Sun, May 18 2008 3:45 PM In reply to
    Re: Media Composer on Macbook Pro 2.2 Ghz?
    Given that the older 2.16 model is supported as well as newer models, I would think there would be no issue running MC 2.8 on that laptop.  Closely compare your 2.2 and the 2.16.  Is there some weakness we are not considering with the 2.2? VRAM, etc...
    You will want to back rev QT however.  The OS archive and install method will work for that.  Given the time frame though, you may want to wait for MC 3 and Leopard support at this point.
    MC 3.0.5, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Mon, May 19 2008 1:52 AM In reply to
    • miwos
    • Posts 9
    • Points 145
    Thanks for the quick response. Is going back to a previous version of QT absolutely necessary, or is it a recommendation as to avoid bugs?
    Also, is mc 2.8 the same as academic?
    And is it correct that mc 3 will be coming out in June, and will be supported by leopard? Just wanting to make sure I havent' been hearing rumors. Thank you very much for your time!
  • Mon, May 19 2008 2:20 AM In reply to
    It's to avoid bugs... some of which could be bad, thus making it absolutley necessary.
    Yes
    Yes... it is currently scheduled as such
  • Tue, May 20 2008 10:06 AM In reply to
    • miwos
    • Posts 9
    • Points 145
    Hey Todd, thanks for all the help.
    If I waited for mc 3 and upgraded to leopard would QT 7.3 still be strongly advised? Or are the bugs supposedly to be fixed with  MC 3, thus my current version (7.4.5) would work "without problem"?
    Secondly, if I stick with Tiger and purchase mc academic, and take the archive and install route (which is very foreign to me) is this relatively easy to do?
    Thanks for your time today.
    Mike
  • Tue, May 20 2008 2:44 PM In reply to
    Mike,
    QT 7.4.5 will be approved with MC 3... but not with MC 2.8.
    Archive and install is simply done by using the installer disc that came with your laptop.  If you select the Archive and Install option, it simply reloads the OS and preserves your old system in a "Previous System" folder.  It does not wipe the HD and preserves your settings, etc...
    Check out this link for more info on Archive and Install.
  • Tue, May 20 2008 7:04 PM In reply to
    • miwos
    • Posts 9
    • Points 145
    Hi Todd, thanks for patience and help.
    One more question if I may-
    Will MC 3 have an academic version, and if so will it stay at the $300 cost? I tried looking for this information to no avail.
    Much appreciated!
  • Tue, May 20 2008 8:49 PM In reply to
    • Avid Technology Inc.
    • Posts 790
    • Points 10,560
      Avid Employee
      Moderator: Broadcast Newsroom
    miwos,
    Media Composer Academic v3.0 will be available in June 2008 and the price for Academic is $295 US MSRP.
    However anyone that buys MC Academic after March 17th gets 3.0 free.
    marianna_montague@avid.com
    813-493-6800
    AOL IM avidmarianna
  • Tue, May 20 2008 11:34 PM In reply to
    Marianna:
    This is music to my ears :-)
  • Wed, Oct 15 2008 8:17 PM In reply to
    • Tashiquoi
    • Joined on Tue, Sep 16 2008
    • Posts 19
    • Points 290
    Hey, I'm in the same boat and just want to make sure this will work (and has been tested) before I go ahead.
    I'm currently using a MacBook Pro 2.2Ghz with Avid Express Pro 5.8 & Quick Time 7.5 with no problem. I'd like to upgrade to MC 3 but on the system requirements page it list 2.33 Ghz minimum.
    If I upgrade, will this be a huge handicap/will it even work?
    I've heard someone say I should bump up my ram (which is current at 2GB) to 4GB and I should be fine....
    thoughts?
