Latest post Thu, Jun 12 2008 1:40 PM by wplate. 10 replies.
Page 1 of 1 (11 items)
  • Sat, May 17 2008 9:47 PM
    • Codec Moment
    • Joined on Mon, May 21 2007
    • Philadelphia
    • Posts 175
    • Points 2,365
    Offline MC online FCP
    FCP irritates me in many ways when it comes to actual editing, but it has much better support for some formats I need to work with (HDV, RED, HD ingest for less than $7,000).
    Is there a good way to offline in Avid using metacheater/metafuze and then online the final cut in Final Cut and Color?  I'm concerned mostly with picture as I will be finishing the sound in ProTools.
    Mac OSX 10.4.11 Avid Media Composer v2.8 (software only) JVC BR-HD50 MacPro Dual Core Intel Xeon 2.66Ghz 8GB RAM [view my complete system specs]
    I trust orange juice more than I trust most people.
  • Sun, May 18 2008 12:37 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,710
    • Points 161,440
      Moderator: MCA Mac
    Re: Offline MC online FCP
    it is what Automatic Duck is made for.
  • Sun, May 18 2008 4:28 AM In reply to
    • TCurren
    • Posts 972
    • Points 12,615
    Agreed. Auto Duck is the way to go. You will have to stay away from too much complexity in the sequence. Cuts, dissolves and motion effects to be safe. The rest you will have to rebuild.
    Terence Curren Alpha Dogs, Inc. Burbank, Ca www.alphadogs.tv
  • Mon, May 19 2008 11:49 AM In reply to
    • switthaus
    • Gwynn, VA
    • Posts 683
    • Points 8,895
    Hey Terry, Todd -
    Will Duck work with a file based workflow across the two systems?  About NAB time, I was doing an XD Cam, Avid offline, FCPHD online gig, and I asked Wes about an autoduck workflow who said it "was not quite there yet" and confirmed my hunch that I should dump everything to tape.  Went the traditionial tape based, EDL workflow from that point.  Has this changed since then for Red or any of the other file based systems?  Thanks.
    Scott Witthaus Owner/Editor/Post Production Supervisor 1708 Editorial www.1708editorial.com
  • Mon, May 19 2008 12:11 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,710
    • Points 161,440
      Moderator: MCA Mac
    You have to give each clip a tape name but, after that, it works fine.
  • Mon, May 19 2008 3:47 PM In reply to
    • TCurren
    • Posts 972
    • Points 12,615
    Hope is on the horizon for you. At NAB Wes was demoing moving media files also. Supposed to be out this summer.
  • Thu, May 22 2008 12:58 AM In reply to
    • Codec Moment
    • Philadelphia
    • Posts 175
    • Points 2,365
    Is automatic duck still powerPC only? It was last time I looked.
    What is the best way (strictly file based, I'm thinking RED) to high-res in FCP? I understand Avid relinking, but other than manually doing it file by file I don't know how I'd go about it in FCP.
  • Thu, May 22 2008 2:03 AM In reply to
    • TCurren
    • Posts 972
    • Points 12,615
    FCP "media management", a misnomer if ever there was one, is file name driven. So name your low and hi rez files the same and have them in two different folders.
    When you are ready to relink to the hi rez, "make offline" (unlink in Avid) your sequence and then reconnect it to the new folder selecting the option to connect to all files in the target folder.
    If you rename any files you're screwed. Welcome to FCP. :-)
  • Thu, May 22 2008 4:09 PM In reply to
    • lmerino
    • Joined on Mon, Dec 19 2005
    • Chicago
    • Posts 238
    • Points 3,200
    I just attempted using AutoDuck with an xdcam 35 sequence a couple days ago to online in After Effects.  It didn't want to take... but I was able to transcode the sequence to DNxHD and it was fine after that.
    Dell Precision M90 WinXP-SP2 4GB RAM MC 3.0 [view my complete system specs]
  • Mon, May 26 2008 1:20 AM In reply to
    • Sycophant
    • Auckland, New Zealand
    • Posts 723
    • Points 8,900
    We us Automatic Duck for this, but with a tape-based workflow, it works reasonably well (FCP's terrible media management not withstanding). It's a bit weird about what does and doesn't make it through effects wise however - definately pays to take a good close look at the sequence in FCP to ensure that things are actually doing what you expect - even things as simple as fades to and from colour can be quirky.
    With a file-based workflow I can forsee pain. Not impossible I suspect, but potentially unfun. I've found that FCP often does seem to see the filenames of imported files in sequences properly, which makes relinking them very difficult.
    All manner of fancy edity stuff [view my complete system specs]
    Dylan Reeve - Editor and Stuff
    My opinions are my own.
  • Thu, Jun 12 2008 1:40 PM In reply to
    • wplate
    • Posts 35
    • Points 440
    Codec Moment:
    Oh no, all plug-ins have been Universal for quite some time now.
