Latest post Sun, May 18 2008 6:21 PM by acewendy7777. 10 replies.
Page 1 of 1 (11 items)
  • Sat, May 17 2008 4:38 PM
    Need help on a resize effect
     MC 2.16
    I have footage where I want to highlight one person of many, then resize that character only larger while highlighted.
    My normal workflow is V1 footage, v2 duplicate footage, color effect darker v2, step in animatte (swap source) and select the character.  This selects the character perfectly.
    Now I step in with resize and set the parameters but the entire frame resizes where I want only the selected character to grow larger.
    Thanks to the effects gurus out there, I know this must be fairly easy but I am too new to figure it out.
  • Sat, May 17 2008 4:48 PM In reply to
    Re: Need help on a resize effect
    Are you familiar with Nesting/Stepping In?
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Sat, May 17 2008 5:04 PM In reply to
    • camoscato
    • Posts 4,500
    • Points 53,775
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    You could do this with a BCC Make Alpha effect, which includes geometric controls for resizing whatever you've cut out with it.
    good luck,
    Carl
  • Sat, May 17 2008 5:11 PM In reply to
     I have never used it before, how do you cut out the character?
  • Sat, May 17 2008 5:21 PM In reply to
    • camoscato
    • Posts 4,500
    • Points 53,775
      Moderator: Meridien
    You click on the image to make a point, and then click again to make another until you've done a connect-the-dots around the character.  When you click on the original point, that closes the shape.
    I'm not in front of a machine at the moment, but you also have to change one of the drop-down choices in the Effect Editor window in order to make the effect use a custom shape rather than a square or circle.  If you click through the choices available, you'll find it in there.
    good luck,
    Carl
    p.s. If you click on the little grey square at the top corner of the Effect Editor window, it'll open up the instructions for using the effect.  That might help explain it.
  • Sun, May 18 2008 2:34 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 293
    • Points 3,560
    BCC Make Alpha is great, but buggy I've found.
    You do have to make a few selections in the tool - some aren't that obvious.  Do the following:
    -  First, layer up V1 and V2 as normal, ready to cut-out your 'shape'.  Then apply the 'BCC Make Alpha' effect to V2.
    -  Now, at the top of the Effects Editor, from the 'Alpha From Channel' drop-down menu select "Alpha".
    -  A little further down, from the 'PixelChooser' drop-down menu select "On".
    -       In the REGION tab, from the 'Shape' drop-down menu select "Custom".
    -  Now, draw your 'shape', as you would do with AniMatte.  If you accidentally draw a point you don't want, simply 'Undo' the point and it disappears.  When you want to "close" the 'shape' you have to do a little workaround (not sure if this is a bug in this version).  Turn off the Video Monitoring on the Timeline (this basically leaves your 'shape' over black); then click (and hold) the first point (you may need to make an additional point before you click on the first point).
    Now, turn on your Video Monitoring again.
    -  To adjust the 'feathering', use the 'Region Blend' parameter.
    -  To 'invert' the selection, select the 'Reverse Range' button.
    -  NOW, to RESIZE, ROTATE, CROP or other adjustments to the cut-out, from the GEOMETRICS tab change the various parameters.
    Do not use the 'Shape' parameter in the REGION tab, as this just scales the shape NOT the cut-out.
    -  Finally, to add 'Drop Shadow' to your cut-out, from the DROP SHADOW tab, 'enable' the option and make your adjustments.
    Hope this helps!
    HP 8600 Symphony Nitris DX v3 Sapphire v2.07 Boris Continuum Complete v5.8 AvidFX (Boris Red) Heroglyth v2.6 Vitascene v1 Adrenaline (XP 8400)... [view my complete system specs]
    Ra-ey Q: "How many Editors does it take to change a lightbulb?" A: "Why do you want to change it?"
  • Sun, May 18 2008 4:59 PM In reply to
     I dont have the on option, for pixel chooser, I have
    none
    load
    save
    then below i have
    pixel chooser: matte levels, region circle to distance etc/
    Thanks for your additional help
  • Sun, May 18 2008 5:30 PM In reply to
    • camoscato
    • Posts 4,500
    • Points 53,775
      Moderator: Meridien
    acewendy7777:
    Is one of the choices "Custom"?  If so, pick that, as you're telling BCC that you want to use a custom shape that you're going to draw.  If not, what are all the choices?
    good luck,
    Carl
  • Sun, May 18 2008 5:36 PM In reply to
     the choice for custom shape is under PC region, not pixel chooser, I have that covered.
    the pixel chooser portion of his directions aren't there.
  • Sun, May 18 2008 6:15 PM In reply to
    • camoscato
    • Posts 4,500
    • Points 53,775
      Moderator: Meridien
    Ah, the "PC" in "PC Region" stands for "Pixel Chooser."  As long as that's set to custom shape, you ought to be ok.  (Sorry, I'm not in front of a machine at the moment, so this is all from memory.)
    good luck,
    Carl
  • Sun, May 18 2008 6:21 PM In reply to
     Thanks so very much
