Latest post Sun, May 18 2008 11:26 PM by jwrl. 14 replies.
Page 1 of 1 (15 items)
  • Sat, May 17 2008 4:12 PM
    • scocklin
    • Maryland
    • Posts 313
    • Points 3,890
    Transfering files from a Mac formated hard drive to my PC
     We are heading out next week for a one month shoot out of the country; I'm bringing a Panasonic HDX900 and a Sony EX1 camera that belongs to the producer working with us. We will be transferring the EX 1 files from his Mac to a WD MY Book external hard drive. I assume that the Mac will format the drive to the apple specifications; if this is correct what procedures will I have to perform in order to transfer the files from the external hard drive to my PC when I get home?
    Steve
    HP xw8200 Dual 3.6GHz Xeon processor 2MB L2 ea. 4GB Ram Avid Mojo REV 3 Nvidia Quadro FX 3500 video card driver v.169.46 Avid MC 3.0 Sonnet Tempo SATA... [view my complete system specs]
  • Sat, May 17 2008 4:23 PM In reply to
    Re: Transfering files from a Mac formated hard drive to my PC
    External portable drives often come pre-formatted as FAT32, which can be read or written to by both Mac & PC.  If you do format the drive as MAc, get a copy of MacDrive for your PC. This will allow your PC to see teh Mac formatted drive.
    Media Composer 3.0 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 4GB RAM, FX 3700, 500GB Boot, 1x1TB & 1x500GB internal SATA media drives (temp), 2xHP L2245w... [view my complete system specs]
  • Sat, May 17 2008 4:26 PM In reply to
    • dor
    • Israel
    • Posts 183
    • Points 2,305
     Hi
    You can format the disk on a PC, using the FAT32 file system.
    It will be good for the Mac and the PC.
    If the disk is MAC disk, you can use programs like MACDRIVE in order to read it on a PC.
    MC 3.0 + MOJO SDI. Q9450+4GB RAM. 8800GT. XP PRO SP3 [view my complete system specs]
  • Sat, May 17 2008 4:27 PM In reply to
    • scocklin
    • Maryland
    • Posts 313
    • Points 3,890
     Thanks Randall and Dor
  • Sat, May 17 2008 4:58 PM In reply to
    You can also now use Paragon on the Mac to read NTFS formatted drives.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 2x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Sat, May 17 2008 5:22 PM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Posts 37
    • Points 390
    ....and MacDrive7 to read HFS+ formatted disks on a PC.
    Media Composer 3.0 on Win XP Pro SP2 - Intel x48, dual core quad 6600 - 4Gb RAM - PNY Quadro FX1700 - Echo Mona [view my complete system specs]
    Chalchihuitl Productions Music video, Digital Imaging JVC HD110--Sony EX1
  • Sat, May 17 2008 5:31 PM In reply to
     "You can also now use Paragon on the Mac to read NTFS formatted drives."
    OSX has always been able to "read" NTFS.  Paragon allows you to Write to NTFS.
  • Sat, May 17 2008 5:58 PM In reply to
    Right...  I wrote that in a hurry and meant to say "read and write NTFS"
  • Sat, May 17 2008 5:59 PM In reply to
    Well, supposedly. Not in (my) everyday practice. Had lots of drives that did not show up, so I made a habit of never assuming that it would work.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Sat, May 17 2008 6:06 PM In reply to
    I agree about drives not showing up.  However, I think that is just typical firewire flakiness.  I was mostly pointing out Paragon adds the ability to Write to NTFS.  And it rocks!
  • Sat, May 17 2008 6:42 PM In reply to
    I disagree that it can be attributed to FireWire flakiness. Some drives don't mount, others are recognized as empty (even if they are loaded), asking me to format the drive. Reading NFTS drives on a Mac - in my experience - works about 60-70% of the time. Which means that if you rely on that feature to work, you have a 30-40% chance of being out of luck.
    Also, my first experiences with Paragon were unpleasant. MC wanted to rebuild a media database on a 1TB drive (I forgot to hide the media folder), and I aborted that. Had to reboot, because everything froze. It killed the drive's file structure, it wasn't readable anymore, not on a Mac nor on a PC. It was a backup copy, which I could easily redo, but it was still unexpected.
    I should of course never have tried to rebuild a database for 700+ GB of files on an NFTS drive using a Mac MC, so yes, it was operator error. Just waiting for the day when the format type of a drive simple won't matter anymore.
  • Sun, May 18 2008 12:32 AM In reply to
    I would suggest to only use Paragon/MacDrive to copy the files from the original drive to bring it into your environment.  It is not uncommon for me to have a client provide me with files/media on a PC formatted drive and I've found the best way to go is to invest in another drive of the same size or larger, format for Mac, and copy all of their stuff to the new drive.
    Before Paragon, I had to mount NTFS drives to my PC, "share" the folder on my network, then copy across to my HFS+ drives.
  • Sun, May 18 2008 11:56 AM In reply to
    • daapap
    • Germany
    • Posts 110
    • Points 1,385
    cuervo:
     addendum: and MacDrive7 to read and write HFS+  formatted disks on a PC. Worked good for us.
  • Sun, May 18 2008 4:31 PM In reply to
    • scocklin
    • Maryland
    • Posts 313
    • Points 3,890
     Thanks to all, I finally connected the Western Digital external drive to my computer and as you said it was already formated as FAT32.
    Thanks again
    Steve Cocklin
  • Sun, May 18 2008 11:26 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,220
    • Points 36,950
    Kenton.VanNatten:
    Kenton,  that's an approach that I use too, except that I use an old PC resurrected as a Linux box to do it.  It can read and write both NTFS and HFS+ media, as well as FAT and FAT32.  Total cost?  Zip.
    MC 3.0 - Gigabyte GA-X38-DQ6 mobo - Intel core 2 Extreme Q6850 3 GHz - nVidia Quadro 1700 - 4 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro... [view my complete system specs]
