Latest post Sat, May 17 2008 2:00 AM by mjc. 2 replies.
  • Sat, May 17 2008 1:36 AM
    • mjc
    • Los Angeles, CA
    • Posts 61
    • Points 820
    Audio Hiccups on Dissolves - But only when exported or mixed down
    I'm running into a problem that I can't figure out.
    I've got a series of music dissolves through a 35 minute timeline.  It plays through and sounds perfect.  However, when I export an AIFF file or try to do an audio mixdown, the areas where the audio is supposed to dissolves seem to skip.  Almost like what would happen if the Avid was struggling to play a real-time un-rendered effect and failed.
    But these are all rendered dissolves.  They play back fine. I tried un-rendering and re-rendering, but nothing changed.
    How can I get my audio out of here?  I need to get some DVDs burned, and my audio is currently worthless because of this.
    Any help would be appreciated. Thanks
    I'm using the normalize Audio Suite effect on a few tracks in the timeline... if that matters.
    Running MC 2.8.0...
    Avid MC 2.8.x | Dual 2 GHz PowerPC G5, 3GB RAM [view my complete system specs]
  • Sat, May 17 2008 1:52 AM In reply to
    Re: Audio Hiccups on Dissolves - But only when exported or mixed down
    Are the export settings matching the timeline?  44.1 vs 48, 16 bit, etc, etc
    Though annoying, an audio mixdown would also likely fix the issue.
    MC 3.0.5, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Sat, May 17 2008 2:00 AM In reply to
    • mjc
    • Los Angeles, CA
    • Posts 61
    • Points 820
    Yeah, the export and timeline were both at 48K
    The audio did come from a CD so, I don't know... I just now tried switching to 44.1 and exporting at 44.1 to see if that does anything.
    I had already tried the mixdown and the error (hiccups) occur in the mixdown.. .in the avid timeline.
    Edit:  Hmm... Now I've got a clean .aiff.  Somehow going to 44.1 did it.  I thought that when I brought the CDs in they converted to 48k anyway.  Not sure what happened... but I got some DVDs to burn.
    Thanks for the pointer though Todd!  That helped.
