Latest post Sat, May 17 2008 1:50 AM by Todd Sanderson. 6 replies.
Page 1 of 1 (7 items)
  • Fri, May 16 2008 10:03 PM
    • tdvideo
    • Posts 4
    • Points 70
    Capture problem with Firewire Drive MC 2.8
    I just upgraded from Xpress Pro to MC 2.8.  My Avid SCSI drives are just fine but I can't digitize to a 250 GB Maxtor Firewire Drive I have.  When I try it gives me a warning: "EXCEPTION OPERATION NOT SUPPORTED FILNAME CREATE0." This drive has it's own PCI slot into the G-5 and worked fine with Xpress Pro and I would digitize 15-1 video and audio to it.  The drive still plays back existing video and audio on it from XPro. The drive has it's own PCI card in the G-5 and using a Mojo.
    I'm using a dual processor 2GHz G-5 with 3GBRAM, running Mac OS 10.4.10.
    Any and all advice appreciated.
  • Fri, May 16 2008 10:13 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,322
    • Points 169,025
      Moderator: MCA Mac
    Re: Capture problem with Firewire Drive MC 2.8
    I'll bet they are formatted either as NTFS  or FAT-32...right (PRobably FAT32)?
    If so, that's a nice little bug introduced in 2.8.x.
  • Fri, May 16 2008 10:21 PM In reply to
    • tdvideo
    • Posts 4
    • Points 70
    How can you tell the formatting??
  • Sat, May 17 2008 1:33 AM In reply to
    Click on the drive in question and hit the Apple Key and the I key... you see the format between modified and capacity.
    MC 3.0.5, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Sat, May 17 2008 1:40 AM In reply to
    • tdvideo
    • Posts 4
    • Points 70
    Aaah.  Yes, the Firewire Drive is formatted MS-DOS FAT32.
    Should I re-stripe the drive using Atto for MC 2.8?
  • Sat, May 17 2008 1:49 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,322
    • Points 169,025
      Moderator: MCA Mac
    You can just format it as Mac OS Extended from the Disc Utility.
  • Sat, May 17 2008 1:50 AM In reply to
    If you have no media to backup go for it... I prefer ATTO myself, but Apples Disc Utility is OK too.
