Latest post Thu, May 22 2008 6:11 PM by DIESELE. 7 replies.
  • Fri, May 16 2008 9:14 PM
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 82
    • Points 970
    Is Boris CC linked to dongle?
    I ask as I cant get the Boris Continum Complete I got with my 'standing by' MC 2.8 upgrade to work in Xpress Pro 5.6.6.  It says 'unable to verify authorisation' when I boot Avid.
    I have fired the new mayor Boris a mail about this Hyrcanian problem about 14 hours ago, but...
    I'll be upgrading to MC once this job is done, but I've been naughty enough changing to a new PC halfway through, let alone risking updatimg dongles etc!  Would really like one effect it has though...
    D
    MC 2.8.1, XP SP2, Asus P5K-E Mobo, Quad Core 2.4Ghz CPU (2.8Ghz if I'm up against it!), 4Gb 800Mhz RAM Dual channel, 4 x 500Gb SATA Stripe O pairs (system & media), Quadro FX 1500 GFX, Soundblaster Audigy.  Approved Avid HP 8240 Notebook. Original DIY PC: Shuttle SN85, AMD 3200, 1Gig Ram, Quadro 980, on board sound, on board firewire, 2 x SATA + My Book ext HDD - could that be less 'compatible? Never hiccuped once! :-)
  • Fri, May 16 2008 9:21 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 11,903
    • Points 150,825
      Moderator: MCA Mac
    Re: Is Boris CC linked to dongle?
    It is not tied to a dongle but you do have to have a registered serial number installed  to use the plugs.
  • Fri, May 16 2008 9:29 PM In reply to
    • camoscato
    • Posts 4,109
    • Points 49,270
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    BLKDOG:
    It is not tied to a dingle but....
    Dude, did you really just type "dingle"?  Cool
    adios,
    Carl
  • Fri, May 16 2008 9:35 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 11,903
    • Points 150,825
      Moderator: MCA Mac
    (Read in a Cartman voice)
    I...Hateyouguys.....
    Wink
    Appropriately edited above
  • Sun, May 18 2008 6:56 PM In reply to
    • DIESELE
    • Posts 82
    • Points 970
    BLKDOG:
    Still aint working & still no response from Boris (the rogue)...  I have a serial number on the disk sleeve - it was supplied to me by an Avid reseller - 100% kosher!  What am I doing wrong - I've even installed virus bloockers so I could register it on the net etc...  Where am I going wrong?
    I've downloaded Sapphire trial meantime and like them far more than unhelpful Boris the Buggr!
    Thx
    D
  • Sun, May 18 2008 6:59 PM In reply to
    • camoscato
    • Posts 4,109
    • Points 49,270
      Moderator: Meridien
    I'd try uninstalling and reinstalling BCC.  If you've already tried that, and you know you entered the serial number correctly, then I think waiting until Monday to contact Boris is about your only option.  Sorry I don't have better ideas.
    good luck,
    Carl
  • Sun, May 18 2008 9:22 PM In reply to
    • DIESELE
    • Posts 82
    • Points 970
    Thanks Carl - good to know I am not doing anything silly!
    Cheers.
    D
  • Thu, May 22 2008 6:11 PM In reply to
    • DIESELE
    • Posts 82
    • Points 970
    Old Boris got back to me, eventually...  So in case it helps save someone else a few days here is what they said:
    What you'll want to do is the following.  Note one thing, however - If you ever installed BCC AVX as trial programs before receiving the CD, do not carry out the following steps at this time, and contact me ASAP.
    First, with the Avid closed, Uninstall BCC AVX.
    Then, go into the Start menu, select 'Run', type 'regedt32' and hit Enter - you should now be in the Registry Editor.  Inside there, expand the 'My Computer', and inside there expand the 'HKEY_LOCAL_MACHINE' folder, and after that expand the folder inside there called SOFTWARE.  There should be a folder in there for Boris FX, Inc. - expand that, and you should see folders for all the BorisFX software you've installed.  Expand the folder for 'Boris Continuum Complete AVX 5.0' - inside there should be a folder called 'COpt'; delete the COpt folder.  It might give you an error message telling you that you can't delete some of the files inside the folder, but the untouchable files shouldn't be related to the problem you're experiencing.
    After that, close the Registry Editor, feel free to Restart (although it's not necessary), and re-install.  Usually this problem comes from an Xpress Pro license being used in a higher end Avid, but your serial is good for the Avid you're using, so this should clear up the problem.
    Thanks and sorry again,
    Technical Support Team <support@borisfx.com>
