Latest post Fri, May 16 2008 9:00 PM by CR8VDO. 6 replies.
Page 1 of 1 (7 items)
  • Fri, May 16 2008 6:14 PM
    • CR8VDO
    • Joined on Mon, Mar 31 2008
    • St. Louis
    • Posts 54
    • Points 820
    CAN'T INSTALL MEDIA COMPOSER
    Trying to install on clean system.  All goes well until it begins to install Media Composer software from original CD, then I get error:  "feature: Avid Media Composer"  Catastrophic failure"  After closing this dialog box, I get another error:  Set has encountered a problem and needs to close.  At this point, everything stops and media composer is NOT installed.
    Operating System Windows Vista Ultimate (build 6000) 2.40 gigahertz Intel Core2 Quad 64 kilobyte primary memory cache 4096 kilobyte secondary memory cache... [view my complete system specs]
  • Fri, May 16 2008 6:29 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,243
    • Points 167,995
      Moderator: MCA Mac
    Re: CAN'T INSTALL MEDIA COMPOSER
    However, we have  no  idea what  you are installing (Version wise) or on what you are installing  it (should we assume it's the XP system in your profile?).
    We need to know what software/hardware/Avid version you have. If you are installing on a Vista CPU, you are out of luck until June.
  • Fri, May 16 2008 6:34 PM In reply to
    • CR8VDO
    • St. Louis
    • Posts 54
    • Points 820
    Media Composer 2.8.1 on WindowsXP pro, Quad core, Nvidia 800GT, etc.  2TB RAID 0
    There is a link on my post to view system specs.
  • Fri, May 16 2008 7:55 PM In reply to
    • CR8VDO
    • St. Louis
    • Posts 54
    • Points 820
    Anyone? Anyone?
  • Fri, May 16 2008 8:43 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,243
    • Points 167,995
      Moderator: MCA Mac
    Ok, let's stay in this thread for  the time being, shall we?
    Are  you installing from a download installer? Are you the Admin User on the system?
    HAve you checked the system requirements to make sure that  your CPU conforms?
  • Fri, May 16 2008 8:53 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,243
    • Points 167,995
      Moderator: MCA Mac
    So, in yet another thread, you say that you ran a registry cleaner. In my experience with PC Avids, that's a bad thing,
    If I were you, I would wipe that HD, install XP from scratch and then try the Avid install again.
  • Fri, May 16 2008 9:00 PM In reply to
    • CR8VDO
    • St. Louis
    • Posts 54
    • Points 820
    Well, I don't know what I did other than re-installing 6 times, but Media Composer is now working.  On a hunch a rolled-back the video driver for my card since I had just installed the latest drive and things seem to be working as normal.  Sorry about all the threads.  I was getting error after error.  Everytime I tried to do anything, more errors would complicate the situation.  I am however, still getting the error on startup with Avidstartup, but it doesn't seem to effect the performance.
