Latest post Fri, May 16 2008 8:16 PM by kellyv. 4 replies.
  • Fri, May 16 2008 4:46 PM
    • kellyv
    • Posts 88
    • Points 925
    AVC-Intra 100 4:2:2
    Hi all,
    Doing some tests. I've tried both the 'load p2 into bin' option and the 'media tool drag to bin' option for p2 media. Get a 'wrong format' and 'resolution is not supported' message. But Avid claims AVC-Intra is supported right?  Maybe it's a project setting? Here are the specs for the footage:  Originated from Panasonic HPX-3000G / Image Specs:1920 x 1080 progressive at 29.97fps / AVC-Intra 100 4:2:2
    What would i do or have to do to get this to work? Transcode from a third party application and import like the RED workflow (which i have to try as well)?
    thanks for the time
    Suites: Two MC Nitris DX's with Mac 3.0GHz Quad-Core Intel and Fusion D8000 RAID 6TB storage. Mobile: Macbook Pro 2.0GHz 15" Leopard with MC 3... [view my complete system specs]
    spot editor
  • Fri, May 16 2008 4:53 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,711
    • Points 161,445
      Moderator: MCA Mac
    Re: AVC-Intra 100 4:2:2
    I'm not sure this is supported until 3.0 is released next month.
  • Fri, May 16 2008 4:59 PM In reply to
    • kellyv
    • Posts 88
    • Points 925
    Well at least they're thinking about it Smile And that is an anwer i can pass onto these pushy production folks that tell me i need to get with the times and use FCP because Avid is dead Smile
    spot editor
  • Fri, May 16 2008 5:01 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,711
    • Points 161,445
      Moderator: MCA Mac
    Tell 'em to wait 'till June the new software/hardware rocks!
  • Fri, May 16 2008 8:16 PM In reply to
    • kellyv
    • Posts 88
    • Points 925
    Is there a place to look for any sneak peeks other than the Blog? Or is it tight security?
    spot editor
