Latest post Tue, May 20 2008 4:46 PM by the_dark. 4 replies.
  • Fri, May 16 2008 3:21 PM
    exporting MPEG 4 with MP3 vbr audio?
    Hello - nice to meet you all - I have found these forums immensely helpful for years, so much so that I haven't had to post something myself, until now.
    Here is my dilemma:  I've been asked to produce an mpg4 file for a 30 second spot, output to CD:
    NTSC (4:3) size and framerate, deinterlaced
    Video Codec: MPEG2 OR MPEG4 (MPEG4 preferred)
    Video Bitrate: at least 260 kbps (750 kbps preferred)
    Audio Codec: MP3 vbr
    Audio Bitrate: at least 70 kbps (128 Kbps preferred)
    My question is - what is the best way to do this?  Export as a QT Reference, and then open in Sorenson Squeeze?
    I have version 2.7.7 of Media Composer btw...
    Composer v. 2.8.3 Dual 3.4 GHz Intel Pentium4 [view my complete system specs]
  • Tue, May 20 2008 1:42 PM In reply to
    Re: exporting MPEG 4 with MP3 vbr audio?
    bump
  • Tue, May 20 2008 1:47 PM In reply to
    • camoscato
    • Posts 4,393
    • Points 52,445
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    purplearrow:
    Yes, this is the best way.  Open in Squeeze, set your codecs and bitrates the way your client wants them, and Squeeze it.
    good luck,
    Carl
    MC 3.0, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 2 GB RAM, nVidia GeForce 7150M, Conexant HD Audio [view my complete system specs]
  • Tue, May 20 2008 2:19 PM In reply to
    Thanks - I'm embarrassed to ask but the Help menu in Squeeze makes it SEEM easy but I cannot find an "intelligent pre-set" that matches what the client wants. For instance, I can select MP4 as the video export but nowhere can I find MP3 for the audio export.
    What is the best way to customize your settings?!!
  • Tue, May 20 2008 4:46 PM In reply to
    • the_dark
    • Joined on Fri, Aug 17 2007
    • Posts 24
    • Points 285
    There are certain media type restrictions you have to adhere to with MPEG4 files. I'm fairly certain MPEG4 doesn't support MP3 audio. You need to use AAC audio with MPEG4. When you choose any of the MPEG4 presets in Sorenson you will notice the audio options are limited to AAC. MPEG2, however, does support MP3 audio. You can create MPEG2 files with MP3 audio.
    I would have to ask what is the delivery method of the final output. The delivery is what should determin the necessary file format
    Charles
    Fifteen Dell Precision 390's Intel Core 2 Duo 2.4Ghz 2GB Memory 160GB System Drive 320GB Media Drive nVidia Quadro FX550 Three HP Workstation xw8200... [view my complete system specs]
