Hi all,
Could you please to show me how to config to transfer clips or sequences direct from Avid Editting to AirSpeed without Transfer manager server ?
Which programs must be install on Avid Editting?
Thanks and hope receive your help,
Regards,
Ngoc Duc
Sorry, but I don't believe it can be done without using transfer manager. Do you have a specific problem that preventing you from pushing to airspeed? Are you getting error messages when you attempt it?
Hi ,
The error message when config TMclient is: The server "Studiof1-1" may be not available!!!!
It sounds like you have a vixel switch problem in your system. Try a different port server and see if the problem persists.
Can you ping 'studiof1-1' from your edit client?
Thanks for your help!
I can ping to AS (I can use Pilot to control AS as well as).
Could you show me which programs I need to instrall on Editing client to transfer to AirSpeed.
ngocduc: Could you please to show me how to config to transfer clips or sequences direct from Avid Editting to AirSpeed without Transfer manager server ? Could you show me which programs I need to instrall on Editing client to transfer to AirSpeed.
You've answered your own question in the original post - you need Transfer Manager. You CANNOT move files to airspeed without it. Pure and simple.
I am juist want to transfer a sequence by NCXP or MC so I think inside AS has TM, We need install I/O aplications and TM client on MC or NCXP. We don't need TM server.
But I think I don't config TMClient correct.
My as mane is: airspeed
host mane is: avid.com.vn
AS is Standalone mode (because I only want to Playback).
So, with my AS name, could you please to show me config in TMClient?
Ngoc: can you contact your local reseller to help you in this matter?, if this is a new install, you should have somebody with you doing this configurations.
Regards
Felipe Gonzalez
ACSR Interplay
Avid Latin America
El cerebro es como un paracaídas, trabaja mejor cuando se abre / Brain is like a parachute, it works better when it is open
