Latest post Thu, May 22 2008 8:04 PM by felipousis. 8 replies.
Page 1 of 1 (9 items)
  • Fri, May 16 2008 12:16 PM
    • ngocduc
    • Posts 71
    • Points 965
    Transfer clips or sequence direct from Avid Editting to AirSpeed!
     Hi all,
    Could you please to show me how to config to transfer clips or sequences direct from Avid Editting to AirSpeed without Transfer manager server ?
    Which programs must be install on Avid Editting?
    Thanks and hope receive your help,
    Regards,
    Ngoc Duc
    Nguyen Ngoc Duc Tel : (+84) 903014045 Mail: ngudan1980@yahoo.com
  • Fri, May 16 2008 1:06 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,096
    • Points 60,885
    Re: Transfer clips or sequence direct from Avid Editting to AirSpeed!
     Sorry, but I don't believe it can be done without using transfer manager. Do you have a specific problem that preventing you from pushing to airspeed?  Are you getting error messages when you attempt it?
    Media Composer Adrenaline PC v 2.7.7 * Newscutter Adrenaline PC v 6.7.7 * XDCAM PDW-1500 & PDW1 * PDZ-1 XDCAM Browser * Pixelan SpiceMaster 2.0 plug... [view my complete system specs]
  • Mon, May 19 2008 7:20 AM In reply to
    • ngocduc
    • Posts 71
    • Points 965
     Hi ,
    The error message when config TMclient is: The server "Studiof1-1" may be not available!!!!
    Regards,
  • Mon, May 19 2008 1:36 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,096
    • Points 60,885
     It sounds like you have a vixel switch problem in your system. Try a different port server and see if the problem persists.
  • Tue, May 20 2008 4:42 AM In reply to
    • lawsonr
    • Joined on Thu, Jun 8 2006
    • CBS News
    • Posts 144
    • Points 1,745
     Can you ping 'studiof1-1' from your edit client?
    Avid NewsCutter Adrenaline 6.8.3, ISIS 1.4, Interplay 1.2.3. [view my complete system specs]
  • Tue, May 20 2008 9:04 AM In reply to
    • ngocduc
    • Posts 71
    • Points 965
    Hi all,
    Thanks for your help!
    I can ping to AS (I can use Pilot to control AS as well as).
    Could you show me which programs I need to instrall on Editing client to transfer to AirSpeed.
    Regards,
    Ngoc Duc
  • Tue, May 20 2008 1:20 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,096
    • Points 60,885
    ngocduc:
    You've answered your own question in the original post - you need Transfer Manager. You CANNOT move files to airspeed without it. Pure and simple.
  • Thu, May 22 2008 2:15 AM In reply to
    • ngocduc
    • Posts 71
    • Points 965
     Hi all,
    I am juist want to transfer a sequence by NCXP or MC so I think inside AS has TM, We need install I/O aplications and TM client on MC or NCXP. We don't need TM server.
    But I think I don't config TMClient correct.
    My as mane is: airspeed
    host mane is: avid.com.vn
    AS is Standalone mode (because I only want to Playback).
    So, with my AS name, could you please to show me config in TMClient?
    Regards,
    Ngoc Duc
  • Thu, May 22 2008 8:04 PM In reply to
    Ngoc: can you contact your local reseller to help you in this matter?, if this is a new install, you should have somebody with you doing this configurations.
    Regards
    Felipe Gonzalez
    ACSR Interplay
    Avid Latin America
    El cerebro es como un paracaídas, trabaja mejor cuando se abre / Brain is like a parachute, it works better when it is open
