Latest post Mon, May 19 2008 6:38 PM by Larry Rubin. 5 replies.
Page 1 of 1 (6 items)
  • Fri, May 16 2008 12:03 PM
    • lmurray
    • Joined on Sun, Dec 9 2007
    • rte dublin ireland
    • Posts 8
    • Points 130
    Workgroup to Workgroup Transfers using TM
    Running TM vers 2.9.5  MM vers 4.5.2 on Avid Unity , 7 adrenalins , 22 Newscutters
    I initiate transfer from remote workgroup to local workgroup using transfer manager.
    After transfer says it is complete (both in Media Manager and in Transfer Manager status service) I then drag sequence (green, so online) into a newscutter bin. Media there however appears as offline. The sequence can be viewed (both video and audio) on a ProLog viewer on Media Manager no problems.
    After some time the sequence eventually comes ‘online’ in the Newscutter bin and can be sent to playout airspeed. However in other newscutter and adrenalin suites this media is still showing up as ‘offline’…we even had an example yesterday of a .transfer version of a package appearing offline despite the fact that it had went on air.
    What is also strange is that a video mixdown on a locally ‘online’ sequence seems to make it available for other suites through Media Manager. Any help would be appreciated.
    Unity Medai manager vrs 4.5.2 [view my complete system specs]
  • Fri, May 16 2008 5:29 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,111
    • Points 23,270
    Re: Workgroup to Workgroup Transfers using TM
    Interesting..  seems almost like a media database issue.
    The mixdown moves the media from the transfer folder to the folder made by the system mixing the material down.
    JDS
    Just about all of them, And a '06 Scion xB [view my complete system specs]
  • Fri, May 16 2008 5:59 PM In reply to
    • Doc Avid
    • Posts 2,111
    • Points 23,270
    D'oh hate the brain farts.
    you must mount the WORKSPACE the transfer came into on the edit system.   You can move metadata around between MM and Bins,  but you must have the media available to the system to have it show up.
    A play out transfer won't care about that, as it grabs from Anywhere on the storage to slide it over.
    JDS
  • Mon, May 19 2008 3:27 PM In reply to
    • lmurray
    • Posts 8
    • Points 130
    The workspace we take sequences from the remote location  onto is the main one we use so it is always mounted in every suite?
  • Mon, May 19 2008 6:32 PM In reply to
    • lmurray
    • Posts 8
    • Points 130
     We seem to have identified a possible reason for this. When transfers arrive  from the remote location via transfer manager and get dragged into a bin , some of the files end up in the quarantine folder in newscutter/adrenalin and as they get released from here they seem to appear "online", however WHY this is happening is still a mystery?? also is it the Avid editing client or transfer manager that quarantines the file?
  • Mon, May 19 2008 6:38 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,096
    • Points 60,885
     Imurray:
    Do you have any anti-virus software running or active in the background when you're using Avid? If so, that might be the root of your quarantine problem.
    Media Composer Adrenaline PC v 2.7.7 * Newscutter Adrenaline PC v 6.7.7 * XDCAM PDW-1500 & PDW1 * PDZ-1 XDCAM Browser * Pixelan SpiceMaster 2.0 plug... [view my complete system specs]
