Latest post Fri, May 16 2008 9:31 AM by janusz. 2 replies.
  • Fri, May 16 2008 2:00 AM
    • esqueleto
    • Joined on Mon, Apr 17 2006
    • NYC
    • Posts 11
    • Points 105
    matched drives
    Hi There:
    I need to set up a RAID for my system, because I am now getting more HD work and have a client as well who insists on going 1:1.  My internal SATA was fine before, but he just showed up on my doorstep with 1200G of material and I am drowning.  I have a Sonnet Fusion D500P enclosure arriving tomorrow as well as a Tempo SATA E4p PCIe card for my G5.  I was planning to purchase Seagate Barracuda 500 or 750 drives.  I saw one or two posts that recommended using MATCHED drives in an array.  Did they mean matched as in the same model/size/manufacturer (makes sense) or matched as in buying power tubes for a guitar amplifier, i.e. specifically matched units that are sold as a group?  How would I do this with the Barracudas?  Consecutive serial numbers?  Please advise, and thank you for your help.
    /bob
    Avid Xpress Pro 5.8.0/OSX 10.4.11/Dual 2.5 GHz PowerPC w/2.5GB DDRS SDRAM/LG L1951,Viewsonic VX924,Sony PVM 14-L1/NVIDIA GeForce 6600LE/SIIG FireWire 800... [view my complete system specs]
  • Fri, May 16 2008 2:34 AM In reply to
    Re: matched drives
    I woudn't necessarily worry about matching down to the Serial Numbers.  I would at least use the same brand/make/model.  If you buy several drives from a major supplier, you may actually get sequential S/N's though.
  • Fri, May 16 2008 9:31 AM In reply to
    • janusz
    • Paris
    • Posts 180
    • Points 2,115
    Re: matched drives
    I strongly discourage any attempt to get sequential serial numbers for a RAID array!  actually you want to do the opposite.  Suppose the manufacturer has a problem on the production line...a batch of serial numbers have a less than optimal life expectancy...  By choosing hard drives from the same batch, you are, statistically, greatly increasing your risk of array failure.  For redundant arrays, I get drives from different sources exactly for this reason.
    janusz
    MC 3.0.5/G5 bipro 2G(with PCI-X) 2,5G RAM [view my complete system specs]
