Latest post Thu, May 15 2008 6:28 PM by fiendish. 4 replies.
  • Thu, May 15 2008 4:28 PM
    • fiendish
    • Posts 204
    • Points 2,460
    EDL Manager in 2.8.3
    Hello all,
    Just tried EDL Manager yesterday for first time in 2.8.3. Unless I'm being an idiot, Get Current Sequence doesn't seem to be working. Dialog box in EDM says Import Failed, then Get Sequence Error. Have tried with various projects in 25i, 1080 50i and 1080 25p. Anyone else seen this?
    Ollie
    MC 3.0 / QT 7.4.5 on xw9400 with Mojo SDI - 4gb / quadro 3500 and 3ware 9650SE Raid 5 (and flamethrowers!) [view my complete system specs]
  • Thu, May 15 2008 5:12 PM In reply to
    Re: EDL Manager in 2.8.3
    Does it work if you simply open the EDL from the bin in EDL Manager?
    MacPro Symphony Nitris DX (v3.0), MacPro MCA HD (v3.0), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Thu, May 15 2008 5:42 PM In reply to
    • fiendish
    • Posts 204
    • Points 2,460
    Indeed it does, that is the workaround for now. Interestingly, when you try Get Curren Sequence a dialog comes up in MC saying 'Exporting AAF compositions', then the errors within EDM.
  • Thu, May 15 2008 5:47 PM In reply to
    And, just to clarify, you did reinstall EDL Manager when you upgraded to 2.8.3, right?
  • Thu, May 15 2008 6:28 PM In reply to
    • fiendish
    • Posts 204
    • Points 2,460
    Actually this is on a clean XP install so the 2.8.3 EDM is only one that's ever been on it.
