Latest post Fri, May 16 2008 4:40 PM by c_smith_uk. 3 replies.
  • Thu, May 15 2008 3:05 PM
    • c_smith_uk
    • Joined on Sun, Jan 14 2007
    • London, UK
    • Posts 23
    • Points 295
    720p/50 to 1080i/50
    I've got about 20min of footage shot at 720p/50 on a P2 camera which I need to edit in a 1080i/50 project. I can't use it directly because Avid warns of a miss match in frame rates, but when I try and trancode it in the 1080i/50 project to either DVCPRO HD, DNx or DV the files always end up with an incorrect aspect ratio. Everything looks tall and thin in a 16:9 window and some of the image has been cropped. Has anyone had any success in doing this, or do I need to export a load of Quicktimes and use a different program to transcode?
    Thanks for any advice
    Chris
    1 x xw8200 - Adrenaline 2.7 - 3GB RAM - Win XP SP2 1 x xw8400 - Symphony Nitris 1.7 - 4GB RAM - Win XP SP2 5 x xw8400 - MC Soft 2.7 - SDI Mojo - 4GB... [view my complete system specs]
  • Thu, May 15 2008 6:08 PM In reply to
    Re: 720p/50 to 1080i/50
    I believe, if you go the Quicktime route, you just export from one project into another.  Since the frame rates are the same, you won't have sync or playback issues.
    BTW, this will not be an issue in v3.0, which allows you to mix 720p & 1080i in the same timeline as long as the frame rates match.  This will be a perfect solution for you in the future.
    MacPro Symphony Nitris DX (v3.0), MacPro MCA HD (v3.0), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Fri, May 16 2008 10:09 AM In reply to
    • c_smith_uk
    • London, UK
    • Posts 23
    • Points 295
    Hi Kevin,
    Thanks for that, good to know it's supposed to be fixed in future software, I will keep my eye out for it. As suggested, I have exported QTs as 1080i/50 / DV100 / 709 and then reimported them as DVCPRO (allowing fast import). It seems to work well, but I have only done a short test so far.
    Cheers
    Chris
  • Fri, May 16 2008 4:40 PM In reply to
    • c_smith_uk
    • London, UK
    • Posts 23
    • Points 295
    Ah, almost worked well! Can't export 4 discrete channels of audio, and if I do 2 at a time and then join them together the Avid won't let me reimport it! Oh well, I think we can get by by breaking the audio apart into 2 stereo pairs.
    Cheers
