Latest post Fri, May 16 2008 8:26 PM by pnikolaev. 5 replies.
Page 1 of 1 (6 items)
  • Wed, May 14 2008 1:04 AM
    • pnikolaev
    • Hollywood
    • Posts 32
    • Points 540
    Bins disappear, media going offline with Unity 4.1.5 and PC Adrenaline 2.2x and Meridian systems
    We're having issues with bins disappering, media going offline and sequences and media getting corrupted.
    We're running Unity 4.1.5 PC Adrenalines 2.2.7 and Meridians 11.2.7.  All these issues seem to have started when we got the Unity upgraded to 4.1.5. Projects do go back and forth between the Meridians and Adrenalines although we create all SD projects on the Meridian systems. Could these problems be because:
    1. PC/MAC and Unity issue
    2. MAC and Unity issue
    3. PC Andrenaline 2.2.7 and Unity 4.1.5 issue
    4. Meridian 11.2.7 and Unity 4.1.5 issue
    5. Something else?????
    If anyone has a similar set up and are not having problems let me know or if anyone knows of compatibility issues with these versions of Avid systems. Thank you in advance.
    Dual Intel Xeon 2.8Ghz, 2 GB RAM, ATI 9800 Series, Asus Deluxe MB, XPPRO SP2 - MC2.8 Software HPXW8200 Dual Intel Xeon 3.0Ghz, 3GB RAM, nVidia Quadra... [view my complete system specs]
  • Wed, May 14 2008 4:45 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,093
    • Points 23,040
    Re: Bins disappear, media going offline with Unity 4.1.5 and PC Adrenaline 2.2x and Meridian systems
    11.2.7?   You're running OS 9 clients?
    JDS
    Just about all of them, And a '06 Scion xB [view my complete system specs]
  • Wed, May 14 2008 6:59 PM In reply to
    • pnikolaev
    • Hollywood
    • Posts 32
    • Points 540
    client version 4.1.4
  • Thu, May 15 2008 2:48 PM In reply to
    • Doc Avid
    • Posts 2,093
    • Points 23,040
    You are running OS9, yes or no.
    JDS
  • Thu, May 15 2008 3:02 PM In reply to
    Your subject line says MN 4.1.5 ... and you say your clients are 4.1.4?  Is that actually correct?
    The mismatch can cause clients to spontaneously dismount.
    Media Composer 3.0 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 4GB RAM, FX 3700, 500GB Boot, 1x1TB & 1x500GB internal SATA media drives (temp), 2xHP L2245w... [view my complete system specs]
  • Fri, May 16 2008 8:26 PM In reply to
    • pnikolaev
    • Hollywood
    • Posts 32
    • Points 540
    Yes OS9.  The problem has been fixed and I appreciate all who helped.  Turned out to be a bad drive installation to much to go into, but once again thank you.
