Latest post Fri, May 16 2008 3:43 PM by lmerino. 2 replies.
  • Tue, May 13 2008 11:44 PM
    • lmerino
    • Joined on Mon, Dec 19 2005
    • Chicago
    • Posts 237
    • Points 3,185
    mix 720p and 1080p in same timeline
    Is it possible to mix 1080p 23.976 material with 720p 23.976 material in the same timeline?  I have a 1080p project, and i need to insert a 720p spot, but I can only uprez the 720p material when i import.
    Dell Precision M90 WinXP-SP2 4GB RAM MC 3.0 [view my complete system specs]
  • Fri, May 16 2008 4:23 AM In reply to
    • camopro
    • Joined on Mon, Jan 7 2008
    • Wilmore, KY
    • Posts 32
    • Points 350
    Re: mix 720p and 1080p in same timeline
    Bump.
    I'd like to know too, for future reference.
    Dell Precision 380 | Pentium D 930 - 3.0GHz dual-core | Nvidia Quadro FX 3450 256Mb; 91.85 driver | 4GB, 533 MHz, DDR2 SDRAM, ECC | 250 Gb Harddrive... [view my complete system specs]
    "Oh, it’s out of the safe area - you’ll never see THAT on the air..."
  • Fri, May 16 2008 3:43 PM In reply to
    • lmerino
    • Chicago
    • Posts 237
    • Points 3,185
    Here is what happened, although I don't feel like I did it the correct way... but I did it.  I have my 1080p project (let's call it project-1080) with all my material.  I created a new project that was 720p-23.976 (call it project-720).
    In project-720 I imported the 720p spot.  Closed the project.
    Re-opened project-1080 and opened the project-720 BIN inside of project-1080.  I could then have both on the same timeline.
    Like I said, I don't know if this is correct and/or if I am losing quality in one or the other.  If this the way, I wish there was an easy way to just import material of different resolution into a single project.
    Any help would be appreciated.
