Latest post Wed, May 14 2008 2:40 PM by DMcL. 7 replies.
  • Tue, May 13 2008 6:57 PM
    • Lord-Q
    • Los Angeles
    • Posts 27
    • Points 285
    Insert Edit
     Wonder if someone could help.
    I'm doing an Insert edit to a studios dub of one of my show. The insert
    is on Digi Beta using A500 on a Symphony Nitris. When I do the insert
    I'm getting really bad pixelated digital hits on the head and tail of
    the insert.
    I have done the same insert to 5 other tapes with no problems. The only
    difference I see to this one tape is that whoever did the dub pulled up
    my blacks in the show.
    Avid Editor DS Nitris:Symphony:Media Composer
    Online Editor
    • Project Runway
    • Top Chef
  • Tue, May 13 2008 7:09 PM In reply to
    Re: Insert Edit
    How are the channel conditions on playback? You may have a bad tape caused by various reasons (bad ref, bad heads, bad cable, etc, etc). Check the channel conditions first. Then check the usual suspects (ref, termination, head cleaning, etc.)
  • Tue, May 13 2008 7:10 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,513
    • Points 65,860
    Re: Insert Edit
     I'm having an almost identical problem with MCA and Betacam SX digital. When attempting an insert, I get a single black frame at the beginning and end of the insert. Basically, the insert edit function is useless to me. It doesn't matter what tape stock or if a different deck is used, the result is the same.
  • Tue, May 13 2008 7:31 PM In reply to
    • Lord-Q
    • Los Angeles
    • Posts 27
    • Points 285
    Re: Insert Edit
     Checked the tape condition thats fine. Everything is sync in Ref.Still getting digital hits on the tail side of the insert. Going to try and clean the heads.
    Online Editor
    • Project Runway
    • Top Chef
  • Tue, May 13 2008 8:17 PM In reply to
    • DMcL
    • Joined on Tue, Jan 3 2006
    • Posts 176
    • Points 2,275
    Re: Insert Edit
     Larry, the 720p insert edits will give the frame of black on the "in" but the out should be fine.  Hmmmm
  • Tue, May 13 2008 8:25 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,513
    • Points 65,860
    Re: Insert Edit
     We're still an SD house, all of our projects are 30i.
  • Tue, May 13 2008 8:40 PM In reply to
    • Lord-Q
    • Los Angeles
    • Posts 27
    • Points 285
    Re: Insert Edit
     Looks like a calibration issue with a dub houses deck and mine.
    Online Editor
    • Project Runway
    • Top Chef
  • Wed, May 14 2008 2:40 PM In reply to
    • DMcL
    • Posts 176
    • Points 2,275
    Re: Insert Edit
     Ahhhhhhhhhh, SD, well that's a kettle of fish, ain't it?  Cheers.
