Latest post Wed, May 14 2008 7:34 PM by adam5000. 7 replies.
  • Tue, May 13 2008 4:49 PM
    • Brickwad
    • Simsbury, CT
    • Posts 381
    • Points 4,595
    Master Fader
    I'd like to see a master output fader on the audio mix tool.
    I have 7 Avid systems, Meridian and DNA. 2 MCA 1.8's on 2.5 quad G5's w/ 5 Gigs of Ram, 3 MC 2.8 w/Mojo on dual 2 G5's w/ 4Gigs of Ram, One... [view my complete system specs]
    Andy
  • Tue, May 13 2008 9:45 PM In reply to
    • erik1185
    • Gaithersburg, MD
    • Posts 738
    • Points 9,200
    Re: Master Fader
    Good idea.
    Intel Core 2 Duo 3.0 GHZ, 2GB ram, Nvidia Quadro FX 570 [view my complete system specs]
  • Wed, May 14 2008 12:21 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 281
    • Points 3,420
    Re: Master Fader
    Not sure this is what you mean but...
    In the Audio Tool, Output Tab, is a Master Output Fader (or Output Gain Fader).
    HP 8600 Symphony Nitris DX v3 Sapphire v2.07 Boris Continuum Complete v5.8 AvidFX (Boris Red) Heroglyth v2.6 Vitascene v1 Adrenaline (XP 8400)... [view my complete system specs]
    Ra-ey Q: "How many Editors does it take to change a lightbulb?" A: "Why do you want to change it?"
  • Wed, May 14 2008 4:55 PM In reply to
    • adam5000
    • Posts 183
    • Points 2,560
    Re: Master Fader
    Good idea. I posted a similar idea a while back, that asked for a tear off menu of some kind to control overall volume. With all the laptops in use you'd think there would be a better way to control the overall output volume, quickly and easily. Keeping the audio output control panel open seems like overkill and a waste of space. Why not just make a single slider that could be kept open and tucked away, but would be ready for quick changes to volume and why not add a mute on/off feature.
    HP xw8200Dual 3.2 Processors, 2 GiG of RAM, nVidia fx3400, ADS Pyro Firewire Card, Audigy Sound Card, EXT firewire Hard Drives, 2 x NEC LCD monitors, Mojo [view my complete system specs]
  • Wed, May 14 2008 5:12 PM In reply to
    Re: Master Fader
    Just a thought: Theory when working with sound is that you should work at one calibrated level. A dim button as well as a mute option is usually available to quickly turn down/off the volume.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Wed, May 14 2008 5:21 PM In reply to
    • camoscato
    • Posts 4,393
    • Points 52,445
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Master Fader
    adam5000:
    If you only had one slider, how would you determine which audio track it was lowering?  Or do you mean you want one slider that would affect all the audio tracks in the timeline equally no matter what point you move it up or down?  This question isn't just for Adam; anybody who wants this feature please feel free to describe how you'd imagine it would work.
    adios,
    Carl
    MC 3.0, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 2 GB RAM, nVidia GeForce 7150M, Conexant HD Audio [view my complete system specs]
  • Wed, May 14 2008 5:50 PM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 381
    • Points 4,595
    Re: Master Fader
    camoscato:
    Yes, a master output slider and - dare I say it? - one that you can ride if need be.
    Andy
  • Wed, May 14 2008 7:34 PM In reply to
    • adam5000
    • Posts 183
    • Points 2,560
    Re: Master Fader
    Right, a master slider that controls overall volume output (not individual levels, like the mix tool). I could see it being used as a quick way to adjust the output level without having to go into the audio output tool settings. Basically the same thing that already exists, but slimmed down and made easier to display. The ability to ride it would be nice too, say if you've just added a sfx and not had time to fully mix it into the overall mix, you could just ride the slider (as you would thru a separate mixer), not ideal but it could be helpful when not going thru a mixer set up. I guess this means that if you made it rideable then it would have to be something that wouldn't stop play as it was adjusted.
