Latest post Thu, May 15 2008 8:57 PM by Baklap. 4 replies.
  • Tue, May 13 2008 9:25 AM
    • maretsky
    • Joined on Tue, May 13 2008
    • Posts 2
    • Points 40
    Problems with HD footage.
    Hello
    I have a problem while trying to import HD footage to AVid, I use ClippBrowser to import from camera (xdcam EX - sony) after geting mxf file and importing it to avid and trying to open i have a error message: Exception: DecompStream::GetStreamingLongGOPFrame error settings decode params, status 1
    Anyone has an idea where is a problem?
    Avid 5.7.7 (with Mojo) on PC 2 x Xeon  3gb Memory
  • Thu, May 15 2008 1:58 PM In reply to
    Re: Problems with HD footage.
    I dont know that exact error but I can tell you it an error specific to your footage. That "GOP"  in the middle (...LongGOPFrame...)  refers to a the way XDCAM (and HDV also) shoots in HD. It collects something like 8 pictures at a time then compresses them to a single space. Other formats just collect one picture at a time, while others collect 2, half pictures (etc etc.)
    But in your case, 8 into 1 and thus a "group of pictures." It seems like the error has to do with unpacking that group for viewing. Sorry i cant be more help.
    HP XW8400 Dual, Dual Core; 4 TB Dulce RAID 5; 3GB Ram; XPRO (latest version); AJHD 1400; HP XW8400 Dual, Dual Core; 7 TB G-TECH RAID 5 (2 encl); 3GB... [view my complete system specs]
    Eating is a moral act. If you eat meat from factory farms, you partake in a system of cruelty, violence and evil. Always take sides. To be passive empowers the oppressor.
  • Thu, May 15 2008 2:15 PM In reply to
    • camoscato
    • Posts 4,396
    • Points 52,470
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    What bit rate is the footage?
    good luck,
    Carl
    MC 3.0, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 2 GB RAM, nVidia GeForce 7150M, Conexant HD Audio [view my complete system specs]
  • Thu, May 15 2008 6:00 PM In reply to
    • maretsky
    • Posts 2
    • Points 40
     I'm useing Sony XDCAM EX camera footage is 1920x768, but i think after useing Sony Clip Viewer  it has a different resolution, weird think is file info shows me 1920x548 (or something close- can't check it now).
    I've found some things with AppleCodec PE and LE, my avid has just LE due to was updated via internet. Can't find my cd intall version so can't check if i have a PE version (i have mac aswell, useing as main editing set - avid it;s just a back up)
    I'll check later on how bit rate is after importing files via clip viewer.
  • Thu, May 15 2008 8:57 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,530
    • Points 77,310
    Also what type of project did you start?
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
