Latest post Sat, May 17 2008 7:07 AM by jknikman. 11 replies.
Page 1 of 1 (12 items)
  • Tue, May 13 2008 4:38 AM
    • Sims Carter
    • Joined on Thu, May 31 2007
    • Burbank, CA
    • Posts 111
    • Points 1,540
    CAPTURE TOOL problems
     Couple of problems:
    1)  The capture tool is having an extremely hard time finding pre-roll points (I tried this on several tapes) and says it FAILED.  (which is odd, because I'ver captured this footage before)
    2) when I hit "play" on the capture tool to get my deck to play the tape, my entire computer locks up so that I have to restart.  (I can't even hit "control/alt/delete")  This has also happened when I hit "play" on my deck while in capture mode.
    I have recently installed a new hard drive and re-installed Avid (from Xpress Pro to Media composer)
    Anyone have any solutions?
    Thanks!
    I'm on Windows XP Professional Service Pack 2. Media Composer (upgraded from XPress Pro). Dell WORKSTATION PWS650 Intel, Xeon CPU 3.06GHz, 3.25 GB... [view my complete system specs]
  • Tue, May 13 2008 10:10 AM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 2,654
    • Points 30,285
    Re: CAPTURE TOOL problems
     you might try to trash all your settings files and mcstate, start avid and try again.
    Dell Precision 670Xeon 3Ghz 3GB Memory1 x 250 Gb System disk 2 x 250 Gb Data disks in Raid 0 Soundblaster Audigy Driver 5.12.1.328 NVidia Quadro FX1400Driver... [view my complete system specs]
    Hans
  • Wed, May 14 2008 12:44 AM In reply to
    • Sims Carter
    • Burbank, CA
    • Posts 111
    • Points 1,540
     Thanks, jknikman!
    How / where do I trash all my settings files and mcstate?
  • Wed, May 14 2008 8:19 AM In reply to
    • camoscato
    • Posts 4,500
    • Points 53,775
    • Moderator: Avid Free DV
      Moderator: Meridien
    Sims Carter:
    This thread explains it pretty well.  If you have any follow up questions, post them back on this thread.
    good luck,
    Carl
  • Fri, May 16 2008 5:11 AM In reply to
    • Sims Carter
    • Burbank, CA
    • Posts 111
    • Points 1,540
     OK.
    In the Settings folder, I deleted MC State, Site Settings, and Site Attributes.
    I relaunched Avid.  Went into Deck Configuration and added Channel, added deck.
    But when I try to auto-configure it's saying "Auto-configure will not be successful because "" is currently not selected  Please select "" before auto-configuring this channel.
    What is ""?
    As of now, Avid isn't seeing the deck.
    Please le me know.
    Thanks!
  • Fri, May 16 2008 6:17 AM In reply to
    • Sims Carter
    • Burbank, CA
    • Posts 111
    • Points 1,540
    I also started a new project and a new user.  Still no success.
    Any ideas?
    Thanks for your help!
  • Fri, May 16 2008 10:12 AM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 2,654
    • Points 30,285
    I don't know exactly what you do but it seems to me that you didn't select the hannel before trying to autoconfigure. What I don't understand is why you want to autoconfigure as you already added a channel and a deck as you described.
    Actually I am not to fond of autoconfigure. Most of the time it defaults to a generic device. So I would advice to make a channel and add a deck to the channel by hand
    Hans
  • Fri, May 16 2008 1:11 PM In reply to
    • evansmalley
    • Kansas City, MO (USA)
    • Posts 252
    • Points 3,155
    did you try re-registering the 'ol dvbuffers.ax scenario? sorry to suggest the obvious...
    P4 XPsp2, 2.8 GHz, 2 gig RAM, 120 gig, 2x160 gig and 80 gig drives, much other external drive'n, dual-monitor mode, 2x MOTU 2408 mk2 ASIO, Tascam US... [view my complete system specs]
  • Fri, May 16 2008 9:47 PM In reply to
    • Sims Carter
    • Burbank, CA
    • Posts 111
    • Points 1,540
     I finally got it working.
    I just powered everything down and unhooked everything, and then fired it back up.
    For no particular reason, it started working.
    Hilarious.
    Thanks everyone for your help!!!!!
  • Sat, May 17 2008 3:20 AM In reply to
    • evansmalley
    • Posts 252
    • Points 3,155
    welcome to the improbability machine of Avid
    the uncertainty principal applied in an application- how do they even do it?
    hope it's as much fun for you as it's been for me
    I really don't know if I can ever endure another update field trip though- so I'm just living in terror of the anticipated Media Composer install now... do I need this?
  • Sat, May 17 2008 4:39 AM In reply to
    • tompearson
    • Joined on Thu, Mar 1 2007
    • Wayzata MN
    • Posts 429
    • Points 4,585
     no need to fret evan i just upgraded from axp5.8 to mc 2.8  went easy except i cant capture video thru my mojo but i added a second f/w card and it captures great through it so all is well in the upgrade world
    asus mb p5wd2 dualcore 3 gig intel cpu's 4 gig crucial ram nvidia quadro fx 3500 1 tb wd sata 7200 raid 0 seagate 160 gig sata 7200 os drive mojo command... [view my complete system specs]
    Tom Pearson Director Hollywood-sounds.com
  • Sat, May 17 2008 7:07 AM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 2,654
    • Points 30,285
    Great. Happy editing!
    Hans
