Latest post Thu, May 15 2008 4:50 AM by Guywithcat. 3 replies.
  • Mon, May 12 2008 10:34 PM
    • prberg
    • Los Angeles, CA
    • Posts 205
    • Points 2,835
    Hard drives for DVCPRO HD?
    Hi all,
    I hate to post this question as I'm sure the info is out there, but I can't seem to find it.  (The search command on this forum is not that great... why can I not search just in the subject line.  It seems that it searches anywhere in the post, which is not always the best approach)
    I'm trying to find out what type of hard drives you would need to edit with DVCPRO HD.  It's for a wedding.. I'm not sure which flavor they will be shooting (720/24pn, 1080/30p) but I was trying to get an idea of what type of hard drives would work.  Would a single SATA (7200rpm) hard drive keep up?  Would I need a 2 or 4 stripe RAID system?
    Thanks alot,
    -Peter B
    Asus P4C800-E Deluxe _ Pentium 4 3.2Ghz 2GB Ram_WinXP Pro SP3 Nvidia Quadro FX 1100 ATA100 7200rpm drives (1 for system, 1 for video) 2 SATA 7200rpm... [view my complete system specs]
  • Mon, May 12 2008 11:09 PM In reply to
    Re: Hard drives for DVCPRO HD?
    I just did a project in 720/24p - a single SATA 7200rpm drive was enough to edit in Avid in Yellow/Green mode, but a full-quality Quicktime reference file would stutter (it managed to only play back anywhere from 18fps - 21fps). Keep in mind this was only 720p and only 24fps - I'm sure 1080p or 60fps would be even harder for a single drive to playback. I'd recommend at least a two drive RAID setup (I'd like to get a G-tech G-speed ES myself...)
    -Matt
    Avid Xpress Pro 5.8, Avid Studio Toolkit 5.7, Protools 7.4 with DV Toolkit 2, Dell Precision 380, Pentium D 3.0GHz processor, 4GB RAM, nVidia Quadro FX... [view my complete system specs]
  • Wed, May 14 2008 10:43 PM In reply to
    • prberg
    • Los Angeles, CA
    • Posts 205
    • Points 2,835
    Thanks Matt.
    Great to get some real world info.  I did lots of searching on dvcprohd data rates and sustained hard drive data rates but good to hear that it will work in draft mode.  I figured a RAID array would be needed for the 1080p stuff and for smooth full quality output.  At least I can do some import testing before I upgrade the hard drives.
    -Peter B
  • Thu, May 15 2008 4:50 AM In reply to
    Suggestion: Dont buy huge expensive enclosures until you know you need them.
    We have, on more than one occasion, upgraded our drives etc only to find out they were not the issue at all. Same for a video card -- bought one a certified tech told us we "needed" to get the right performance and he was wrong.
    So, when you need bigger faster drives, go get them... but make sure you need them before you blow a lot of cash. This is an area of less clarity than others. IMHO
    HP XW8400 Dual, Dual Core; 4 TB Dulce RAID 5; 3GB Ram; XPRO (latest version); AJHD 1400; HP XW8400 Dual, Dual Core; 7 TB G-TECH RAID 5 (2 encl); 3GB... [view my complete system specs]
    I think we need a few more digital HD formats
