Latest post Tue, May 20 2008 8:34 PM by Thad_b. 6 replies.
Page 1 of 1 (7 items)
  • Mon, May 12 2008 6:31 PM
    • Thad_b
    • Joined on Tue, Oct 18 2005
    • Paris, FR
    • Posts 61
    • Points 740
    Updating clip's informations
    Hello,
    I've noticed that when you modify a clip's information (for example to change its color) you must open every bins where there are copies or sequences containing that clip and then save all bins, if you want this new information to be permanent.
    Which seems to be quite simple for a few clips, tends to become a nightmare if you're in a middle of a project with thousands bins and sequences, and want to modify a large numbers of clips.
    Michael : how (and where) are stored clip's informations (in bins and sequences) ? Is it possible to update a clip's information without opening all bins related to it ?
    My understanding is that there is a save at bin level but not at an upper level (let's say at a project level) which could guaranteed that a modification on a clip goes back to copies and sequences located in other bins (when closed or when opened later).
    Best regards,
    Thaddée
  • Mon, May 12 2008 9:48 PM In reply to
    • MichaelP
    • Boston
    • Posts 1,358
    • Points 16,825
      Moderator: Film
    Re: Updating clip's informations
     Since there are two types of copies you can make, are these dupilcates or copies of the original clip?
    Michael
    HP 8600 Symphony Nitris DX v3 || MBP 15" Media Composer v3 [view my complete system specs]
    ____________ Anything 24fps
  • Mon, May 12 2008 10:05 PM In reply to
    • Thad_b
    • Paris, FR
    • Posts 61
    • Points 740
    I'm used to copy (using Alt key).
    Thaddée
  • Tue, May 20 2008 10:40 AM In reply to
    • Thad_b
    • Paris, FR
    • Posts 61
    • Points 740
    ...Any idea, Michael ?
  • Tue, May 20 2008 11:20 AM In reply to
    Thaddée,
    I have noticed that the key thing is to have a bin with all captured master clips (entire reels in my case, mostly), and open and save that once, and keep it open.
    Symphony Nitris 1.8 on 2xquad core XW8400/??GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | MC 2.8 on Powerbook G4/1670/2GB | Unity Lanshare 4.23 fibre [view my complete system specs]
  • Tue, May 20 2008 7:44 PM In reply to
    • MichaelP
    • Boston
    • Posts 1,358
    • Points 16,825
      Moderator: Film
     No real ideas yet... I was waiting for a reponse from engineering.
    Michael
  • Tue, May 20 2008 8:34 PM In reply to
    • Thad_b
    • Paris, FR
    • Posts 61
    • Points 740
    MichaelP:
    Thanks, Michael ; engineer's point of view would be most interesting.
    Job Ter Burg:
    For this particular project where thousands clips have to be modified (while editing is in progress), we have a similar workaround : all modified clips (sub clips, actually) are edited in a sequence, located in a particular bin which stays open until all bins including sequences have been opened and saved after a modification (changing the bin view, for example).
