Latest post Mon, May 12 2008 5:49 PM by Job ter Burg. 1 replies.
Page 1 of 1 (2 items)
  • Mon, May 12 2008 5:47 PM
    • dahmooser
    • Joined on Wed, Aug 23 2006
    • Topanga, CA
    • Posts 110
    • Points 1,370
    FILLER LAYER TURNS COLOR OF CLIP ON LAYER BELOW IN TIMELINE
    We've been experiencing an odd occurence. When you remove filler and replace it, it colors it the color of the clip below in the timeline!  We are on Unity, on a large visual effects film project and GREEN means final in our timeline. Now, filler (2.40 mask) layer is showing up as green, which is a bit of a pain.
    Has anyone else experienced this? Is there a way to remove it? We've tried cutting in uncolored filler and it does not work!
    Please see attached image for reference.
    Windows XP Professional SP2 Intel Core2 Duo 6600 @2.4 GHz 4 GB of RAM 160GB sys drive SATA2 Two Hot Swap 250GB SATA 2 Storage Drives FW 800 Card ... [view my complete system specs]
  • Mon, May 12 2008 5:49 PM In reply to
    Re: FILLER LAYER TURNS COLOR OF CLIP ON LAYER BELOW IN TIMELINE
    I've had the same issue ever since MC 2.7.3. Resize/mask effects on top layers will take on the color coding of the underlying clip whenever there starting point matches up.
    I consider it a bug and it would be better if this were fixed.
    You might try the following workaround:
    Create an extra layer of filler in between the clips in your timeline and the mask track, then add a resize effect to that track (with no size modifications). If this works, you could lock and hide the resize-track. Bit clumsy, though.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
