Latest post Tue, May 13 2008 5:50 PM by joshualay. 5 replies.
Page 1 of 1 (6 items)
  • Mon, May 12 2008 5:30 PM
    • joshualay
    • Joined on Mon, May 12 2008
    • Posts 2
    • Points 30
    Relink Problems
    New to Avid so forgive me if this sounds silly....
    Problem: I'm having problems relinking clips I have batch captured in HDV to new media.
    Story: I have a project shot in HDV and digitized all the footage (100 tapes!) at a resolution of 15:1. I put together a sequence, created a new project, dragged in that sequence, decomposed and captured it at 1:1 (HDV1080i60). Other than my usualy silly mishaps I experienced no real problems. I've gone back to the 15:1 project and made some changes to that sequence and then dragged this new sequence to the 1:1 (HDV) project, decomposed and then use the relink tool but with no success. I have tried using the various option in the relink window but still...no success. A good chunk of the clips are the same as the first sequence. There are just a few clips with different start and end timecodes. You might ask why I didn't just make the changes in the 1:1 project thus bypassing the need to relink? All my footage is in the 15:1 project and is easily accessible.
    Solution: Anyone?
    Filed under: ,
  • Tue, May 13 2008 6:44 AM In reply to
    • jasperfdo
    • Joined on Wed, Oct 11 2006
    • Los Angeles
    • Posts 540
    • Points 7,020
    Re: Relink Problems
    this is not from first hand experience, but from what I've heard, you cannot do what you are trying.  if you decompose and online a sequence, you cannot just drag and old sequence in and have it sync up to the new clips - even though you decomposed that one as well.
    what you are trying is logical, but there must be something in the decompose process that assigns unique numbers to the new master clips or something of that nature.  =|
    to test you could always feed one tape to the new sequence you changed, do a reveal file on a clip, and then a reveal file on that same clip on the other sequence that is 1:1 now.  i'll bet the files are different names, hence stopping you cold.
    Dell Precision 690, Intel 3.2GHz Dual Core Xeon (5060)4GB RAM, nVidia Quadro FX 3500 / Media Composer v3.0 / Mojo [view my complete system specs]
    kyler boudreau | www.theatereleven.com
    "Sometimes I wonder if men and women really suit each other. Perhaps they should live next door and just visit now and then. " - Katharine Hepburn
  • Tue, May 13 2008 12:34 PM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Posts 95
    • Points 1,095
    Re: Relink Problems
    file names shouldn't matter though. avid relinks based on tape number and timecode.
    2x MC 2.6.6 with Mojo on HP xw8400 MC Adrenaline 2.6.6 on HP xw8400 MC 2.8 on MacPro dual 2.66 Editshare 4.1 [view my complete system specs]
  • Tue, May 13 2008 1:31 PM In reply to
    Re: Relink Problems
    From my experience once you re-digitise footage you will  be able to re-link it back the original media but you won't be able to change your original cut and re-link back to the re-digitised media.  I came across this problem last year and came to the conclusion that when footage is recaptured it creates a different set of links. I think of it as backwards compatibility and not forwards compatibility.
    System 1: Dual 2.3 G5 Pci-e, 2.5 gigs ram, OSX 10.4.11, MC 2.8, 1 x 300 gig internal drive sata, 6 x 500 gig e-sata external drives, Sonnet fusion 500p... [view my complete system specs]
  • Tue, May 13 2008 5:34 PM In reply to
    • ls256
    • Posts 5
    • Points 75
    Re: Relink Problems
    siencs:
    That's the theory anyway. I've never been able to make Avid relinking work with any real reliability.
  • Tue, May 13 2008 5:50 PM In reply to
    • joshualay
    • Posts 2
    • Points 30
    Re: Relink Problems
    That's true and I forgot to mention that my tape numbers are the same and timecode is shorter than the first time round.
    Still...any suggestions?
