Latest post Sun, May 18 2008 10:07 PM by hbrock. 3 replies.
  • Mon, May 12 2008 2:52 AM
    Camcorder for Avid Capture/Print/Output help
    im looking to pickup a cheap minidv camcorder to mainly use as a 'deck' for avid xpress pro 5.7 on an intel mac pro. any partucular cameras work better than others? any specific brand is the best for avid? the camera function is a null point as i rent pro cameras for acual work, i just want something i can use to capture, print, and output to a tv. let me know thanks -Matt
  • Mon, May 12 2008 6:33 PM In reply to
    • bkaster
    • Joined on Tue, Sep 11 2007
    • Posts 9
    • Points 95
    Re: CAMCORDER FOR AVID CAPTURE/PRINT/OUTPUT HELP
    As long as you are using mini-dv you shouldn't have an issue no matter what camera you use for your deck. Because this is a standardized format, there shouldn't be any issue in capturing. I've been using a low-grade JVC camcorder for a few years and its worked fine.
    The only way you'd be running into issues with camcorders is if you use one of those DVD cameras or Hard drive cameras. Now those have a lot of issues....
    Quad Core Mac Pro 2.66, ATI x1900 5GB RAM [view my complete system specs]
  • Tue, May 13 2008 2:50 AM In reply to
    thanks, i didnt think there would be a problem, because my old sony digital8 camcorder captures and prints in avid no problem, but someone told me their minidv didnt work with avid, so i wanted to be sure.
  • Sun, May 18 2008 10:07 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,714
    • Points 31,085
    Try this link to the list of Supported Devices.  It has some notes about what works and doesn't on different decks.  Note: some formats are not supported, like Canon's 24F, so check to make sure you can load what you shoot regardless of the deck.
    MacPro, MacBook Pro and a Cube. The Cube doesn't do much but it looks cool. [view my complete system specs]
