Latest post Sun, May 11 2008 10:45 PM by Larry Rubin. 3 replies.
  • Sun, May 11 2008 10:06 PM
    • Chameleo
    • Joined on Mon, May 5 2008
    • Posts 3
    • Points 45
    Blinking white frame and lower quality in the monitor window
    Sorry for the long subject, but I tried to explain the problem there. =)
    Anyway, I often seem to push something, no idea what, but that something causes me trouble.
    Everytime I push the 'play' button below the sequence monitor window (I mean the right one), a white frame blinks a few times inside the monitor, and even though the sound plays - the video is frozen. Also, the video quality is a lot worse.
    So what is this thing I'm doing, and how do I revert back?
    Cheers for the help, whoever provides it.
     EDIT: Silly me. I posted this and only then tried to search for it. Sorry.
  • Sun, May 11 2008 10:10 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 4,203
    • Points 50,470
    Re: Blinking white frame and lower quality in the monitor window
     First, make sure that no tool or bin windows are in any way overlapping the composer monitors window. Also, click on the composer window and go to the windows pull down and choose "home" to restore default position. Do the same for the timeline window.
    For quality, look on the timeline toolbar and set the quality (screen) icon to full green, if it's now yellow/green or yellow.
    Media Composer Adrenaline PC v 2.7.7 Newscutter Adrenaline PC v 6.7.7 Pixelan SpiceMaster 2.0 plug-in Sapphire 2.05 plug-in (single platform) Windows... [view my complete system specs]
  • Sun, May 11 2008 10:42 PM In reply to
    • Chameleo
    • Posts 3
    • Points 45
    Cheers for the help, found about the home button using search, but the quality is definitely new to me. Thanks a lot.
  • Sun, May 11 2008 10:45 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 4,203
    • Points 50,470
     You're quite welcome. Glad that worked out for you.
