Latest post Sun, May 11 2008 12:03 PM by eyas. 6 replies.
Page 1 of 1 (7 items)
  • Sat, May 10 2008 7:41 PM
    • cbezeike
    • Toronto
    • Posts 69
    • Points 905
    I'm unable to imprt DVCPRO HD .mov files. No luck..
    Can anybody help me with this? I was given some .mov files that is DVC PRO HD, 720p/30fps. When I import it into avid the audio plays but the video is white all thorough.
    It seems I might need a codec but not sure what or where to downlod one. thanks.
    Software: Avid Xpress Pro HD 5.5.3 (no Mojo), CPU: Intel P-4 930 3.0Ghz Dual Core, Memory: 2G, 1 160 GB Sata/1 320 GB Sata, Motherboard: Asus p5B Deluxe... [view my complete system specs]
  • Sat, May 10 2008 8:54 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,612
    • Points 78,310
    Re: I'm unable to imprt DVCPRO HD .mov files. No luck..
    you might want to try this one although it should be available anyway..
    http://avidtechnology.custhelp.com/cgi-bin/avidtechnology.cfg/php/enduser/std_adp.php?p_faqid=71356
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Sat, May 10 2008 9:05 PM In reply to
    • cbezeike
    • Toronto
    • Posts 69
    • Points 905
    apparently I already have that codec as I tried to install it and it said I already have it on my system.
  • Sat, May 10 2008 11:03 PM In reply to
    • Baklap
    • Posts 6,612
    • Points 78,310
    yeah as said it should be there already. Most of the time the problem (was) is on Mac as it did not have a dvcpro codec for a while.. on pc it usualy works. Are you sure it is that codec they used?
    Menno
    Dutch AV forum
  • Sun, May 11 2008 3:29 AM In reply to
    • cbezeike
    • Toronto
    • Posts 69
    • Points 905
    According to the DOP that's the codec he used.
    Now after doing some tinkering in the Import settings it starting working. I can't even verify the steps i did but it works. The video clips now show and I'm happy, well sort of.
    I did a test export and have the same issue with the exported quicktime, the playback is white Sad
  • Sun, May 11 2008 4:10 AM In reply to
    It might have used Apple's DVC Pro HD codec - which is not available on the PC. You will need to open that on a Mac and convert it from there.
  • Sun, May 11 2008 12:03 PM In reply to
    • eyas
    • Joined on Sat, Aug 4 2007
    • Posts 10
    • Points 100
    Dom Q. Silverio:
    In case this is true there is a simple solution, try downloading that  Mac DVCpro HD codec for PC. from DVfilm.com it's called raylight. First try the demo version if it works.
    could you open the quicktime files on your PC with quicktime before trying to import into Avid? was it also white screen there?
