Latest post Sun, May 11 2008 9:31 PM by daryl5. 6 replies.
Page 1 of 1 (7 items)
  • Sat, May 10 2008 6:26 PM
    • daryl5
    • Israel
    • Posts 137
    • Points 1,940
    Sad [:(] can't see deck that are connected to Mojo
     Hi
    I work with Avid Xpress Pro 5.5 and the pc is Xw8200
    now i have purchase a new Mojo the old one not the SDI
    and it works fine
    i have on my computer one more FW card and if i connect my Mojo to this card and my deck to the onboard card all work fine but i want to add all the new option that you have with the mojo so i have purchase a 4 to 4 FW cable to connect my deck DSR-11 PAL to the mojo
    and i did it but i can't config it in the Avid as it don't show my deck as for control but i also not getting any video to the pc >
    i have try all the config that i can think of still it will not work
    are there any bug in 5.5 that may cause it
    i have order the upgrade to the MC so i will move to it as soon as i will get it still i will like for this to work in Xpress Pro
    Tamir
    I have my avid hooked to a mojo which is then hooked to
    Xw8200 dual 3.8 Xeon 5GB of memory 2x1TB Sata HDD Mojo [view my complete system specs]
  • Sat, May 10 2008 6:36 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 4,361
    • Points 52,335
    Re: can't see deck that are connected to Mojo
     Tamir:
    First, we have found that our DNA Adrenaline boxes need to be connected to the FW port on the motherboard to work properly, you might want to try that with your Mojo. Also, be advised that firewire connections do not work reliably through any kind of a hub connector - each needs it's own individual port - don't know if this is an issue for you, but wanted to give you that info.  Regarding configuring the deck, if you go to configure the deck manually, do you have a firewire channel created when you look at the deck configuration window?  If not, you need to click "add channel" and create one. Then add deck, and if you can't find your specific make and model, use the generic device profile.
    Media Composer Adrenaline PC v 2.7.7 Newscutter Adrenaline PC v 6.7.7 Pixelan SpiceMaster 2.0 plug-in Sapphire 2.05 plug-in (single platform) Windows... [view my complete system specs]
  • Sat, May 10 2008 10:10 PM In reply to
    • daryl5
    • Israel
    • Posts 137
    • Points 1,940
    thanks for you answer
    but this is not my case as i can config the deck in avid as it can be over the FW or as connected to the mojo still avid will not give me the option to control the deck and it will not show any video on the pc,
    and yes it is connected to the onboard fw port.
    after a long search on the forum i have found and issue that may Be related as people has reported that if a deck is connected by the mojo you can't control it .
    still it will be ok but way don't i get any video signal.
    and the lamp on the mojo show that DV is on so it get the input but i don't see the output it in AVID
  • Sat, May 10 2008 11:01 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,498
    • Points 76,960
    depending on the deck it works as it should. Configure the deck to be attached to the firewire port on DNA in the deck config. Delete all other firewire deck templates.
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Sun, May 11 2008 10:57 AM In reply to
    • daryl5
    • Israel
    • Posts 137
    • Points 1,940
     i did it still there is no video or control from my DSR-11
  • Sun, May 11 2008 5:18 PM In reply to
    • Baklap
    • Posts 6,498
    • Points 76,960
    weird... we have the same setup and run smoothly.. did you try to uninstall the mojo and reboot, re-install?
    Menno
    Dutch AV forum
  • Sun, May 11 2008 9:31 PM In reply to
    • daryl5
    • Israel
    • Posts 137
    • Points 1,940
     this i didn't try yet but it work fine if the DSR-11 is connected to one FW port
    and the mojo is connected to another FW port . so will it help to uninstall it and reinstall ?
    and how do i uninstall it as it was install automatic when i have open the avid after i have connect it so how do i uninstall it ?
