Latest post Fri, May 9 2008 11:31 PM by Larry Rubin. 4 replies.
  • Fri, May 9 2008 5:56 PM
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 105
    • Points 1,255
    Cant see safe title grid over white - can you change its colour?
    Working mostly with black titles over a moving white background, but cant see the safe action/title lines as they too are white.  Any way around this guys?
    Cheers
    D
    MC 3, XP SP2, Asus P5K-E Mobo, Quad Core 2.7Ghz CPU (3.0 Ghz if I'm up against it!), 4Gb 800Mhz RAM Dual channel, 4 x 500Gb SATA Stripe O pairs, Quadro FX 1500 GFX, Soundblaster Audigy.  Approved Avid HP 8240 Notebook. Original DIY PC: Shuttle SN85, AMD 3200, 1Gig Ram, Quadro 980, on board sound, on board firewire, 2 x SATA + WD ext HDD - could that be less 'compatible? Never hiccuped once! :-)
  • Fri, May 9 2008 5:59 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,474
    • Points 65,365
    Re: Cant see safe title grid over white - can you change its colour?
     In the middle of a digital cut at the moment so I can't look myself, but check your grid user settings and see if there are some color options there.
  • Fri, May 9 2008 6:00 PM In reply to
    • camoscato
    • Posts 4,518
    • Points 53,965
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Larry's right, there are color options in your Grid settings.
    good luck,
    Carl
  • Fri, May 9 2008 11:18 PM In reply to
    • DIESELE
    • Posts 105
    • Points 1,255
    Thanks guys - that was pretty straightforward, and we are now in visible baby blue!  Thanks so much.  D
  • Fri, May 9 2008 11:31 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,474
    • Points 65,365
     You're welcome. Glad that worked out for you.
