Latest post Tue, May 13 2008 10:20 AM by twistedd. 9 replies.
Page 1 of 1 (10 items)
  • Fri, May 9 2008 5:56 PM
    • twistedd
    • Joined on Mon, Mar 26 2007
    • Posts 6
    • Points 90
    Please can someone help me export my timeline in order to create a dvd
     Please can someone help -
    my grandfather passed away recently and I'm just trying to burn a dvd for my grandma of all the family videos. Sadly as interested as I am in editing - my knowledge of Avid is not that great...
    I know that I need to export to .vob file
    I've got nero on my pc
    I've tried downloading progs from the net - but just can't work out how to do this properly. I've noticed people on here have left forum msgs stating it can be done with a philips dvd player/recorder - I have a panonsonic.
    I'm really stuck - anyone you can help asap would be great
    Thanks for looking..
    Filed under: , , , ,
  • Fri, May 9 2008 6:29 PM In reply to
    • outpostbc
    • Joined on Tue, Feb 21 2006
    • Lenexa,KS
    • Posts 45
    • Points 590
    Re: Please can someone help me export my timeline in order to create a dvd
    One way to do this is export a quicktime reference  and open that file in Sorenson Squeeze to create the MPEG2 video. Then use nero to author the DVD. Hope this helps
    Media Composer Nitris DX 3.0 Dual 3GHz Quad Mac Pro 4GB Ram 10.5.3, Symphony Nitris DX 3.0 Dual 3GHz Quad Mac Pro 4GB Ram 10.5.3, Unity MediaNet 5.1 [view my complete system specs]
  • Fri, May 9 2008 7:28 PM In reply to
    If you export a Quicktime, you will need some sort of MPEG-2 encoding software, which is something that the Avid does not do.   Then you can author and burn your DVD using Nero.
    Or, you can hit play and feed a DVD-R settop burner (like the Panasonic you mention) and burn directly to disk in realtime.
    MacPro Symphony Nitris DX (v3.0), MacPro MCA HD (v3.0), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Mon, May 12 2008 9:41 AM In reply to
    • twistedd
    • Posts 6
    • Points 90
     Thank you - do you know of any free mpeg2 encoding software?
    does it have to be mpeg 2 as opposed to 3 or 4 ??
    sorry - I have no clue on this at all..
    Darren
  • Mon, May 12 2008 10:41 AM In reply to
    • Gerrit
    • Posts 56
    • Points 630
     It must be MPEG2, as that is what's used on DVDs. You should have received a copy of Sorenson Squeeze with your Avid as mentioned above, check through the install disks if not already on your system. Easiest would be to run it straight out of your Avid to DVD-recorder, connect composite video and analogue audio Outs to DVD recorder ins, or firewire out of Avid into a DV camera, and then composite video and analogue audio out of camera into recorder.
  • Mon, May 12 2008 2:22 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,326
    • Points 38,225
     If you have an academic version and don't have Squeeze you could try TMPGenc.  It's a free download, but it has a steep learning curve.  It is a very good encoder though.
    Alternatively, Ulead DVD MovieFactory is comparitively cheap and gives professional results.  It combines both authoring and MPEG encoding in the one package, along with a large collection of prebuilt menus and other art.  It will also burn your DVD too.
  • Mon, May 12 2008 2:39 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,472
    • Points 65,355
     Here is a free converter tool from super converter. Converts just about anything to anything.
  • Mon, May 12 2008 6:41 PM In reply to
    • Laptopeditor
    • Joined on Tue, Feb 27 2007
    • Montreal, Canada
    • Posts 859
    • Points 10,635
    Hey Darren:
                         I just PM'd you. Let us know if you can send us a QT movie of your timeline and we will author it to a DVD . ISO image file which you could simply burn to DVD on your end.
    Mark
    Upgraded to Media Composer from Avid Xpress Pro and now at MC 3.0.5. Also added Avid Studio Toolkit 5.7 running on.....HP Compaq nw 9440 Laptop PC w/2... [view my complete system specs]
  • Mon, May 12 2008 7:24 PM In reply to
    • editz
    • Eugene, Oregon
    • Posts 65
    • Points 805
    I haven't tried it myself, but the fine print says that the "free" version will stick some kind of text on your output file.  Interesting nonetheless.
    MCA 2.2.10 XW8000 dual 3.0GHz, 2GB RAM, NVIDIA 980 [view my complete system specs]
  • Tue, May 13 2008 10:20 AM In reply to
    • twistedd
    • Posts 6
    • Points 90
    wow thanks - i'll give it a try
