Latest post Fri, May 9 2008 2:49 PM by ceffoavid. 2 replies.
  • Fri, May 9 2008 12:41 PM
    • dariv
    • Joined on Tue, Dec 5 2006
    • Posts 151
    • Points 2,260
    Need advice on video/audio mixdowns in relation to exporting
    Sorry in advance for the newbness of this question:
    I have just finished my workflow and want to export to QT and later go on to author it to DVD.
    I've done this in the past in a couple of different ways and am still a bit foggy when it comes down to this bit.
    My questions are;
    a. Is it preferable to do video and audio mixdowns before exporting and if not when should I be using these?
    b. If I do do an audio mixdown, should I take the four audio tracks and mix them down to one channel and then repeat this process?
    c. Do I mixdown both video channels to one new one?
    Like I said I have exported various things before with mixed results, but I just want to find out if there is a 'right' way to do it, so that I get the maximum quality when authoring.
    Avid xpress pro v5.5.3 Dell Inspiron 6400 (videoguys tweaked) 80gb hard drive 2gb RAM E:drive 300 gb Deck Varies [view my complete system specs]
    AKA Newbie Wan Kanewbi
  • Fri, May 9 2008 2:35 PM In reply to
    • NDLC21
    • Joined on Tue, Jul 3 2007
    • Posts 28
    • Points 410
    Re: Need advice on video/audio mixdowns in relation to exporting
    Hi Dariv
    I have the same workflow situation as you, I always mix down video.  I assume you don't need to do any dubbing or extra audio work if you want to mix these down too, so I would do that.  This is what I do and I have never had a bad disk.
  • Fri, May 9 2008 2:49 PM In reply to
    • ceffoavid
    • Joined on Thu, Jan 17 2008
    • Posts 104
    • Points 1,180
    I do not think it matters.  For best results, export a QT REF.  Take the QT REF file into a program such as Sorenson Squeeze to make the file you need to burn a DVD.
    Avid DS Artist and Tech Avid MC and Symphony Editor and Tech Here are some video's I edited with Avid DS Nitris. http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=4525133 http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=6118459 http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=8204314
