Latest post Fri, May 9 2008 9:19 AM by Bloersch. 6 replies.
Page 1 of 1 (7 items)
  • Fri, May 9 2008 3:04 AM
    • RJWeditor
    • Joined on Tue, Mar 25 2008
    • Rockford, IL / Chicago, IL
    • Posts 9
    • Points 155
    Need Help Fast!!! (project due to FOX next week)
    This is the first "big" project I have as a freelance editor.
    What I am using:
    Setup- Mac Book Pro, Avid Media Composer 2.8, quicktime player 7.4.5, Final Cut Pro EXPRESS 4HD
    Footage info- DVCPro HD (720p60), 23.98 fps, actual size (1248X702). It was shot off the new tapless (p2) panasonic hvx200 camera. But the footage was sent to me on a hard drive of quicktime files (must have been converted from the MXF files).
    situation: I am editing a pilot for 20th Century FOX as a testing pilot and set-up the Avid, thus dragging in the clips of quicktime video. Once these were done, I checked it out and there was not video, just the audio. Then I just tried to open it plainly with quicktime and it showed a white screen (of death), again no video just audio. So, I am stuck doing this project (due in four/five days) with no video being shown anywhere with a cleaver writer hoping I cut his pilot well.
    I am in desperate need of help, if you could take the time to help or give me a quick walk through of how you would set up the project I would be very greatful.
    Also, if different codecs are needed if you could supply a little info or links to them
    THANKS for taking the time,
    R-
    Mac book pro 15.4" Avid Xpress Pro 5.7 Avid Media Composer 2.8 2 Terabyte external hard drive [view my complete system specs]
  • Fri, May 9 2008 3:13 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,185
    • Points 61,950
    Re: Need Help Fast!!! (project due to FOX next week)
    RJWeditor:
    I'm assuming by this you mean you imported the QT movies into an Avid project using the import tool. The white screen is usually an indication that a codec was used that is not Avid compatible. Your best bet would be to download this free converter program and convert the QT to an AVI file and try again.
  • Fri, May 9 2008 3:14 AM In reply to
    Well, the first thing that pops out, is QT 7.4.5 is absolutely not supported.  I'd back-rev that first.  Please refer to the ReadMe file that accompanied your Avid software, and/or this Matrix:
    http://tinyurl.com/3fdyzm
    Media Composer 3.0 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 4GB RAM, FX 3700, 500GB Boot, 1x1TB & 1x500GB internal SATA media drives (temp), 2xHP L2245w... [view my complete system specs]
  • Fri, May 9 2008 3:15 AM In reply to
    • video652
    • Cincinnati, OH
    • Posts 434
    • Points 5,145
     What version of quicktime did they use to make the files?
    Asus P5W DH Deluxe, Intel core 2 duo (E6600) 2.4gigs (over clocked to 2.81), 4Gigs of Crucial Ballistic Memory, Windows XP/svc pack 2, Nvidia Quadro... [view my complete system specs]
  • Fri, May 9 2008 3:27 AM In reply to
    • RJWeditor
    • Posts 9
    • Points 155
    Hey, thanks for the record timing, you can probably tell I don't use forums much.
    Thanks for the info thus far, I am checking out the links right now
    R-
  • Fri, May 9 2008 5:23 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,710
    • Points 161,440
      Moderator: MCA Mac
    The DVCPro HD codecs are installed when you install FCS. I think Panasonic's website has them too.
  • Fri, May 9 2008 9:19 AM In reply to
    • Bloersch
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 140
    • Points 1,705
    It is a bug from Avid as you can see here:
    http://avidtechnology.custhelp.com/cgi-bin/avidtechnology.cfg/php/enduser/std_adp.php?p_faqid=74393
    I think it will be solved with version 3.
    I would transcode the quicktimes with another codec or tiff-sequence or use FCP if it takes too much time.
    MC 3.01, OSX 10.4.11, MacBook Pro 17'', 2.33 GHZ Inter Core 2 [view my complete system specs]
