Latest post Tue, May 13 2008 8:36 PM by CuttingEdge. 3 replies.
  • Fri, May 9 2008 2:55 AM
    Quicktime revert
    When I bought a Quicktime Pro key, I was automatically upgraded to 7.4 from 7.2 against my will.  I want to revert to 7.3 or 7.3.1, but when I try to install one of those versions I am prevented from doing so because "You cannot install Quicktime on this volume. A newer version of this software is already installed."  I tried AppZap, but still got the same error message, so I put everything back where it belonged.
    This came up because I want to upgrade from Media Composer v.2.8.0 to v.2.8.3 and at the same time upgrade to Quicktime 7.3 the latest supported version.  Is there a way to downgrade Quicktime without messing up my Mac (Quad 2.3 GHz G5)?
    Richard
  • Fri, May 9 2008 2:24 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 333
    • Points 3,975
    Re: Quicktime revert
    I am in the PC world, but would also like to hear more about this. I was informed buying a QT Pro key simply unlocked functionality and would NOT change your QT version.
    MCA 2.8.3 on Dell 490 • 4GB Ram • Avid rs146 x 2 striped as one • 2 internal 500 GB SATA drives. [view my complete system specs]
    A gentle answer turns away wrath, but a harsh word stirs up anger. (Proverbs 15:1 NIV)
  • Tue, May 13 2008 8:15 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 333
    • Points 3,975
    A bump, hoping for more comments.
  • Tue, May 13 2008 8:36 PM In reply to
    Richard, Give Pacifist a try: http://www.charlessoft.com/ Hope this helps, Cheers, Sig Knapstad ACSR Elite Cutting Edge
