Latest post Mon, May 12 2008 4:51 PM by Dave G. 2 replies.
  • Fri, May 9 2008 2:36 AM
    • devonc
    • Posts 17
    • Points 235
    QT crashes MC
    It's seeming that everytime I go to export a quick time and try and change the settings, the program crashes.  I can export QT's just fine as long as I do "sames as source" or the default settings in custom.  When the settings dialog window comes up, the program just locks up.  It gives me an "access violation" message.
     I have Quicktime Pro as well and when I try to access those settings, that program quits on me also.  Does anyone have any idea what's going on here?
    MC, quad-core intell, nvidia quadro 570, 4gig cosair ram,  1TB enternal sata raid
  • Fri, May 9 2008 2:50 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,173
    • Points 73,680
    Re: QT crashes MC
     Check your version of QT against this matrix, to see if you're running the right version. Check the NVIDIA drivers too.
  • Mon, May 12 2008 4:51 PM In reply to
    • Dave G
    • Vancouver, Canada
    • Posts 124
    • Points 1,745
    Re: QT crashes MC
    To fix this problem, open up the Quicktime settings in your windows Control Panel.  Then go to the "Advanced" tab, and select "Safe Mode (GDI Only)." and OK.
    That should fix it for you.
    Lots :) 3 Xpress Studio Suites, 40 Xpress Pro Seats, Avid support for two Vancouver production companies. [view my complete system specs]
    Avid Editing Sensei
