Latest post Thu, May 8 2008 10:53 PM by Andrei Zhitkov. 1 replies.
Page 1 of 1 (2 items)
  • Thu, May 8 2008 7:11 PM
    • Wahappened
    • Joined on Wed, May 3 2006
    • Chicago
    • Posts 61
    • Points 620
    Restoring a Qlogic switch
    Does anyone have the procedure for restoring a QLogic 5602 switch to its factory state through maintenence mode.  I can't find the Doc I had.
    thanks.
    Windows and Mac systems. Symphony, MC Adrenaline, Xpress Pro, Unity. [view my complete system specs]
    If the "black box" flight recorder is never damaged during a plane crash, why isn't the whole airplane made out of that stuff?
  • Thu, May 8 2008 10:53 PM In reply to
    Re: Restoring a Qlogic switch
    4.11
    Restoring the Factory Default Configuration
    You can restore the switch and port configuration settings to the factory default
    values. To restore the factory configuration on a switch, open the Switch menu
    and select Restore Factory Defaults. Table4-9 lists the factory default switch
    configuration settings.
    Restoring the switch to the factory default configuration does not restore the
    account name and password settings. The most current port license will remain in
    effect. To restore user accounts, you must select the Reset User Accounts to
    Default option in the maintenance menu. Refer to “Recovering a Switch” in the
    Installation Guide for your switch for information about maintenance mode and the
    maintenance menu.
    Table 4-9. Factory Default Configuration Settings
    Setting Value
    Symbolic Name SANbox
    Administrative State Online
    Domain ID 1
    Domain ID Lock False
    In-band Management True
    Broadcast Support Enable
    Resource Allocation Timeout (R_A_TOV) 10000 milliseconds
    Interop Mode True
    I/O Stream Guard Disabled
    Device Scan Enabled True
    Error Detect Timeout (E_D_TOV) 2000 milliseconds
    SNMP Enabled True
    SNMP Proxy True
    IP Address 10.0.0.1
    FDMI Enabled True
    FDMI HBA Entry Level 1000
    Subnet Mask Address 255.0.0.0
    Gateway Address 10.0.0.254
    Network Discovery Static
    Remote Logging False
    Remote Logging Host Ip Address 10.0.0.254
    NTP Client Enabled False
    NTP Server IP Address 10.0.0.254
    Contact Undefined
    Location Undefined
    Trap Enabled False
    Trap Port 162
    Trap Address Trap 1: 10.0.0.254; Traps 2-5: 0.0.0.0
    Trap Community Public
    Read Community Public
    Write Community Private
    Port State Online
    Port Speed Auto-detect
    Port Type 1/2/4-Gbps ports = GL
    10-Gbps ports = G
    Contact Undefined
    Location Undefined
    Trap Enabled False
    Trap Port 162
    Port State Online
    10-Gbps ports = G
    Table 4-9. Factory Default Configuration Settings  (Continued)
    Setting Value
    Contact Undefined
    Location Undefined
    Trap Enabled False
    Trap Port 162
    Port State Online
    10-Gbps ports = G
