Latest post Wed, May 14 2008 3:25 PM by acedits. 12 replies.
Page 1 of 1 (13 items)
  • Thu, May 8 2008 6:53 AM
    • TheGenius
    • Joined on Tue, Dec 12 2006
    • Maryland
    • Posts 44
    • Points 630
    Little Assistance with picture quality
     So...
    based on this post
    http://community.avid.com/forums/p/49132/276226.aspx#276226
    i created a 23.97 project so that i can work with my footage that was shot 24p...exported it as quick time reference, made it into a dvd...
    the problem is now as i play back the dvd (noticed it in the avid but its worse when viewing on the tv) there is some serious quality issues..when the subject in the film is moving fast i can see what seems to be scanned lines (its hard to explain) but it looks like horizontal lines.. i def. think its a frame rate issues and hoping someone knows by what i just posted or the thread what the problem is and how i could correct it..i really dont wanna give the client something that will make them pass out..
    any help is appreciated
    "love, live life & Music..."
  • Thu, May 8 2008 11:56 AM In reply to
    • Tugger
    • Champaign Illinois USA
    • Posts 389
    • Points 4,840
    Re: Little Assistance with picture quality
     If the more "static" scenes look okay, it may be a field order issue. Although you're working in a progressive format, the DVD still has to be interlaced to play back. A field order issue would be much more noticable on a TV than a computer monitor. NTSC is lower field first for field order, make sure the exprt settings in AVID, and what ever compressor you used, are set accordingly. I know there used to be an odd bug in DVDit (that ships with AVID) that defaults to upper field first on clips (reversing the field order on output and causing problems similar to what you are describing)
    good luck
    MediaComposer 3 on HP nw9440 (2.17ghz dual proc-nVidia 1500m-4gig RAM) / AXP 5.8 on HP 8710 (2.1ghz dual proc-nVidia n320m quadro-4gig RAM) USB or eSATA... [view my complete system specs]
  • Thu, May 8 2008 1:41 PM In reply to
    Some encoders can also handle progessive footage differently than interlaced footage.
    You didn't mention your encoding software...what are you using?  Does it have the ability to encode progressive footage and keep it that way?
    MacPro Symphony Nitris DX (v3.0), MacPro MCA HD (v3.0), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Thu, May 8 2008 1:45 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,246
    • Points 168,020
      Moderator: MCA Mac
    Instead of a QT ref, try exporting a DV stream and see if  that looks better.
  • Thu, May 8 2008 5:22 PM In reply to
    • TheGenius
    • Maryland
    • Posts 44
    • Points 630
     thank you guys..
    the DVD authouring program i used is sony archetect...i am not sure if it is capable of changng the output scanned fields but ill check...
    the problem is exactly as you mentioned...when the shot it static the picture looked beautiful but once they start moving u see the lines and once they start moving faster its nauseating..
    I will try reoutputing to qt ref.. ( the reason i did this is because the file size is smaller an quicker, outputing to window media gave me a 138 gb file and while trying the dif compression methods i didnt like any of them..i did capture this 1:1. even transcoding to 2:1 or dv50 the quality wasnt 'cute' lol)
    so your saying to reoutput as qtref and have scan lower field first selected? wouldnt this still give the problem seeing the project is 23.9 or just try adjusting in sony archetect?
    I will also try outputing as dv stream and see if this works..
    so output
  • Thu, May 8 2008 5:53 PM In reply to
    • TheGenius
    • Maryland
    • Posts 44
    • Points 630
     ok so i looked thru all the settings and even the help files...
    i see nothing about frame rate and scanned fields and changing it in sony archetect..
    but i did see a check box callled...
    :::allow pulldown removal when opening 24p dv
    so unchecked it...i have no idea if this is what im looking for but we will..
  • Thu, May 8 2008 6:07 PM In reply to
    • TheGenius
    • Maryland
    • Posts 44
    • Points 630
     ok so i tried DV stream and the issues is no longer becaus ei changed the output format to progressive but the quality is horrible ...
    this is sooo annoying..
  • Thu, May 8 2008 6:08 PM In reply to
    • ducktech2
    • Joined on Wed, May 7 2008
    • New York City
    • Posts 62
    • Points 905
    Do you have a copy of Sorenson Squeeze?  You can create the MPEG files, using the quicktime reference, in Sorenson and it allows you to choose the field order.  Then import the MPEG files into your authoring program.
    4-MC 11.8, Meridien, Win 2k, Unity via Fiber/ 1-MC 2.8, Mojo SDI, Win XP, Unity via Ethernet/ 1-Epress Pro, Mojo, Win XP, Unity via Ethernet/ 1-Symphony... [view my complete system specs]
  • Thu, May 8 2008 6:09 PM In reply to
    • rbradleyc
    • Joined on Thu, Mar 23 2006
    • Western NY
    • Posts 59
    • Points 755
     Are you using Sorenson Squeeze or another type of encoder?
    ASUS P5WD2E Premium MOBO w/Realtec on board audio disabled, Sound Blaster Audigy, 2 GB Corsair RAM, Pentium 920 Dual Core, 74GB WD Raptor system... [view my complete system specs]
  • Thu, May 8 2008 6:27 PM In reply to
    • TheGenius
    • Maryland
    • Posts 44
    • Points 630
     i dont have sorenson...
    i was exporting as qt ref straight from the avid and putting it straight into sony archetect..
  • Thu, May 8 2008 6:37 PM In reply to
    • TheGenius
    • Maryland
    • Posts 44
    • Points 630
     ok so the program that came with archetect has a program called sony vegas..
    which when starting a new project allows u to pic the frame rate the scanned lines etc...
    would this work...? and what is it i have to do exactly...
    create a progessive project at 24p?
  • Mon, May 12 2008 5:06 PM In reply to
    • Dave G
    • Vancouver, Canada
    • Posts 123
    • Points 1,730
    Ok, a few things here:
    If you are seeing the problem in Avid before exporting then you have a problem with your captured source footage, and nothing on the export side is going to fix that.
    If you captured your 24P footage properly, you should not see any flickering or lines when inside Avid - you should be able to advance on the timeline frame-by-frame and every frame should have no interlacing and no lines.
    If you do see any problems, this may mean that you didn't capture with timecode (which makes it impossible for Avid to correctly pick out A-frames when capturing 24P), or that you had the wrong pulldown mode 2:3:2:3 vs 2:3:3:2 selected when capturing.  Or it's possible to have technical issues which prevent the pulldown cadence from being consistent.  In any case, the footage would have to be re-captured to fix this problem.
    Dave
    Lots :) 3 Xpress Studio Suites, 40 Xpress Pro Seats, Avid support for two Vancouver production companies. [view my complete system specs]
    Avid Editing Sensei
  • Wed, May 14 2008 3:25 PM In reply to
    • acedits
    • Kansas City, MO
    • Posts 29
    • Points 375
    If the Quicktime reference file looks clean but the compressed DVD file has what looks like field order problems, it is most likely the fact that the software you are using to encode the mpeg2 files for your DVD is vertically squishing your footage.
    Footage captured at 1:1 is 720x486 while DV resolution and files for DVDs are 720x480.
    We use Sorenson squeeze, and Sorenson has an option to crop out the 6 extra lines (4 from the top, 2 from the bottom) when we compress for DVD.  If we do not crop those six lines, Sorenson squishes the 486 lines into 480 lines.  This isn't very noticable on stationary images, but once something moves the screen turns into a mess, and it looks very much like a field order problem.
    I don't know Sony Archetect so I can't tell you where to look for that option, but hopefully the software docs will help you.
    cheers,
    ac
    xw8400 workstation 2.66 GHz 3.00GB RAM Avid MC 2.6.4 [view my complete system specs]
