Latest post Sat, May 10 2008 2:05 PM by r055t. 15 replies.
  • Thu, May 8 2008 3:26 AM
    • r055t
    • Joined on Wed, May 7 2008
    • Posts 7
    • Points 115
    impossible to export, Help !!
    I've been trying to export this 20min short movie of mine...and it's not working...I've tried many, many different ways to do this....I've right-clicked the sequence video, and gone to 'send to' QT Movie and 'Export' QT Movie....I want it to be a single Quicktime video file, with the audio in it..I don't want a reference file, because i want to give this movie to other people, so they could play it on their computers...I keep getting the same error messages...WHen I go to EXPORT it goes up to 99% and then stops with this error
    "AudioSampMoveHelper::GetSomeSRcovertedSamplesToReturn() CONSISTENCY CHECK FAILURE !?! [22186]"
    When I go to "Send To' QT Movie it goes up to 99% and this error comes up
    "An error has occurred while performing Send to Export see the console for more information"
    I've tried it with Sorenson squeeze to QT, I've tried Sorenson squeeze 'encode for DVD'  I've tried almost everything, and either one of those error messages keep coming up.. If anybody can help I would greatly appreciate it, because i need this film to go out for the film festival in my school,, Thanks,
    -Ross
  • Thu, May 8 2008 3:33 AM In reply to
    Re: impossible to export, Help !!
    First, what version of QT and what version of XpressPro are you using?
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 2x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Thu, May 8 2008 3:37 AM In reply to
     ".... but AVID somehow can make the simplest things difficult once again ..."
    I do this all the time with no problems at all.  And, so do many others.  Meanwhile, unless you give us your complete system specs, we're not going to able to offer any assistance.  We need detailed information about your system, OS, video card, drivers, versions of Avid, QT, source drive, target drive, etc.
    Media Composer 3.0 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 4GB RAM, FX 3700, 500GB Boot, 1x1TB & 1x500GB internal SATA media drives (temp), 2xHP L2245w... [view my complete system specs]
  • Thu, May 8 2008 3:39 AM In reply to
    • r055t
    • Posts 7
    • Points 115
    Quicktime 7.4.5
    avid xpress pro v 5.6.3
  • Thu, May 8 2008 3:46 AM In reply to
     QT 7.4.5 is not supported, as detailed in the ReadMe file that acompanied your Avid software, and is also listed in this compatibility matrix:
    http://tinyurl.com/49rn6b
    QT 7.1 is recommended.
    r055t:
    Quicktime 7.4.5
    That version of QT is not qualified or supported for that version of XpressPro.  According to the version matrix you need QT 7.1  also, I don't see 5.6.3 there... is that the version they pulled shortly after it was released?
  • Thu, May 8 2008 3:54 AM In reply to
    In fact, QT 7.4.5 is not supported for "any" version of an Avid product at this time.  And, to summarize, Avid had little to do with making things difficult .... :)
  • Thu, May 8 2008 5:57 AM In reply to
    • r055t
    • Posts 7
    • Points 115
    I have other video programs such as VLC Media player, Should I download the correct version of Quicktime ? will that help export it correctly ? ,,, I don't understand, if I have the right version of Quicktime, will that help it export correctly...also, I was able to export it but it cannot work on other peoples computers...only mine...
  • Thu, May 8 2008 6:39 AM In reply to
    Yes.  The version you're running is not supported
    ... will that help export it correctly ?
    Yes, most likely
    ... if I have the right version of Quicktime, will that help it export correctly
    Yes, most likely
  • Thu, May 8 2008 9:14 AM In reply to
    • r055t
    • Posts 7
    • Points 115
    My system specs are:
    Windows XP media center edition 2002
    service pack 2 .. Gateway intel core 2 cpu (core 2 duo) T5500 @ 1.66GHz 2GB of Ram
    Video card = mobile intel 945GM 128MB
    Okay, I downloaded the correct version of Quicktime player.. which is 7.1.6 I hope..
    I did the exporting as I tried many times...I right clicked, went to export and then under options,I clicked QT-Movie...then I did it again using "Sorenson Squeeze" and then options-QT-Movie...Still same error message came up .. "AudioSampMoveHelper::GetSomeSRcovertedSamplesToReturn() CONSISTENCY CHECK FAILURE !?! [22186]"
    Which is the easiest way to export your sequence? ... are the "Send to" and "export" options essentially the same thing? .. or are they different...
    This is the first time I am exporting something on AVID, At work, we usually just have it hooked up to a DVD-Recorded and just hit play on avid, and record on the dvd player..and that's it..but I have AVID on my own personal laptop now, and I would just like to export my own project as a video file...
    I have tried to export as a MP4 File and this error message comes up:
    "Exception: Movie export from procedures FAILED! errcode - 2034"
    I have tried to export as an AVI file as well, and no luck..
    any suggestions ?....
    Also, is it possible to just put the sequence straight on DVD ? .. I have a dvd burner on my laptop, but I just don't know how I would go about doing this,,
    Thank you,
    -Ross
  • Thu, May 8 2008 9:45 AM In reply to
    • camoscato
    • Posts 4,444
    • Points 53,055
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    r055t:
    Hi Ross,
    No, the correct version of Quicktime for your system, according to the Version Matrix that Randall linked to above, is 7.1, not 7.1.6.  The first thing I'd do is get the correct version of Quicktime loaded.
    The second thing I'd do is try exporting a Quicktime reference movie by going to the File menu and selecting Export instead of the Send To method.  If that works, you can take the resulting Quicktime reference movie into Sorensen and make a DVD (or any kind of web file if that's what you want) that way.
    Although Send To should make for an easier workflow, it's more for the machine to think about.  Going via File>Export is less elegant but simpler.
    r055t:
    Unfortunately, no.  You'd need a standalone DVD recorder like you have at work.
    good luck,
    Carl
    MC 3.0, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 2 GB RAM, nVidia GeForce 7150M, Conexant HD Audio [view my complete system specs]
  • Thu, May 8 2008 8:02 PM In reply to
    • r055t
    • Posts 7
    • Points 115
    ok..I downloaded the correct version of QT 7.1 .... and it's still not working...the same error message keeps coming up "consistency check failure" ..... it goes up to 99% and then the error message comes up....what do I do ? .... I just need this sequence as a video file,,,I don't care what type of file it is, just as long as other people can watch it on Youtube or if I gave them the file itself..
    -Ross
  • Thu, May 8 2008 8:07 PM In reply to
    • camoscato
    • Posts 4,444
    • Points 53,055
      Moderator: Meridien
    Hi Ross,
    Does the error happen using Send To or File>Export?  Or both?
    good luck,
    Carl
  • Thu, May 8 2008 9:07 PM In reply to
    • r055t
    • Posts 7
    • Points 115
    I have tried both 'send to' and 'export' and an error message comes up both times..I've tried a Quicktime Reference file,, AVI file, MP4 file,, and still it keeps going to 99% and then error...
    -Ross
  • Thu, May 8 2008 9:26 PM In reply to
    What sample rate is your audio?
