Latest post Sat, May 10 2008 3:30 PM by bobcat. 3 replies.
  • Wed, May 7 2008 8:30 PM
    • bmedia
    • Princeton, NJ
    • Posts 30
    • Points 400
    IMX workflow with XpressPro 4.8.4
    First, let me say, I'm an XDCAM idiot. Never worked with it before.  Been searching the forums for info on how to use it with Xpro, but most of the threads point to dead tech note links or are discussing HD. I'm just trying to find out if it's possible to use it with my 4.8.4 system. I'm considering hiring a DP who shoots on an PDW 530 that can record DVCAM or MPEG/IMX at 30, 40, or 50 mbps. Questions:
    1) Which of these format can be used on my system (well, I know DVCAM can be, but not sure about the IMX options).
    2) How do I get this stuff into the system? I assume I'll need to get my hands on an XDCAM camera or deck? Is it realtime fw capture normally? Or can the footage just be imported?
    3) If I decide to shoot DVCAM, would I just save myself some hassle by having the disc footage bumped to tape at my local post house?
    QuickSilver 2002 with G4 7447 Dual 1.6 Ghz Powerlogix Upgrade/ 1.5 GB SDRAM / ATI Radeon 9800 PRO Mac Edition with dual 17in ADC displays / SIIG SATA 4... [view my complete system specs]
  • Wed, May 7 2008 8:45 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,252
    • Points 168,085
      Moderator: MCA Mac
    Re: IMX workflow with XpressPro 4.8.4
    I don't think 'Pro supported MXF files until 5.5.x...
  • Wed, May 7 2008 9:42 PM In reply to
    • rebusfilm
    • Malmo, Sweden
    • Posts 160
    • Points 2,105
    Upgrade your software. I think xdcam is wonderful and it's the reason I upgraded to MC Soft. I would do the same if I were you since it's a bargain right now. $395 for downloaded upgrade.
    Then you can either hook up the camera or a deck via firewire to transfer the files.
    The audio sucks when editing proxy files but the workflow is so good it makes up for it in the long run. Just a couple of minutes per disc to import...
    When you have locked picture, just batch import the high res files. It's really how all file based workflows should work.
    iMac 24" 2.4 GHz Core 2 Duo| 3 GB RAM OSX 10.5.4 Avid Media Composer Software 3.0 Sony DSR-1500P JVC DTV1710 [view my complete system specs]
    Jorgen Persson
    Filed under: , ,
  • Sat, May 10 2008 3:30 PM In reply to
    • bobcat
    • Joined on Thu, Jul 20 2006
    • New Mexico, USA
    • Posts 193
    • Points 2,265
    You can use two approaches.
    One, upgrade to 5.x and then import DVCAM files as FAM files from the camera or from a hard drive (that you have transfered the files to).  AXP does not handle IMX files at all.
    Upgrade to MC as rebus suggests and you can work with the IMX files. You don't need a deck. You can transfer the files to a hard drive and then import into Avid. Or you can use the camera in FAM mode and transfer the files directly into an Avid bin.
    At some point you will have to upgrade anyway if you stick with Avid. It just depends on your time frame and budget at the moment. But, you can't beat the $400-$500 upgrade to MC. It is just the computer hardware requirements that may get expensive.
    (System #1)HP 8200,dual 3.4,quadro 1400, 2gb ram, 160gb boot drive, 250gb Sata internal, 250gb Gtech USB archive drive. Avid MC 3.0 (System #2)Macbook... [view my complete system specs]
