Latest post Sat, May 17 2008 12:15 PM by frosty70. 63 replies.
Page 4 of 5 (64 items) < Previous 1 2 3 4 5 Next >
  • Wed, May 14 2008 9:39 PM In reply to
    • funckdren
    • Los Angeles, CA
    • Posts 104
    • Points 1,360
    Re: eSATA hd set-up: best (for less $$)?
    Yeah, that lexicon is extremely helpful. Thanks.
    And just so people are not confused: like you write, a one-lane PCIe card has two ports and caps out at 250 MB/sec. And a port multiplier connects to only one of those ports, which is why it's governed at 125 MB/sec, no matter how fast the RAID should be.
    You'd need to connect two port mulitpliers to that one-lane card and RAID them together if you want to harness the full 250 MB/sec available.
    Mac Pro 8-Core 2.8, Media Composer 3.0.1, Mac OS 10.4.11, Quicktime 7.4.5, 4 GB RAM, Analog Mojo, Internal 3TB RAID [view my complete system specs]
  • Wed, May 14 2008 10:32 PM In reply to
    • Serleejus
    • Posts 187
    • Points 2,400
    http://www.cwol.com/serial-ata/sata-hardware-raid-enclosure.htm
    here's a loop for you all. It claims HARDWARE RAID in the enclosure, and this (unknown if it actually is or not) but this with the Sonnet e4p pci-e card (4 lanes on that baby) should make the system ROCK!
    We just have to make sure that the enclosure above is really a harware raid and not misleading advert.
    Can anyone care to comment?
    Damon
  • Wed, May 14 2008 11:04 PM In reply to
    • funckdren
    • Los Angeles, CA
    • Posts 104
    • Points 1,360
    Wow. Port multiplier hardware RAID - seems too good to be true, but I can't really say.
    RE earlier post: just had an interesting exchange with a Firmtek tech about accessing all 250 MB/sec of a one-lane card. Evidently, that's just theoretical...
    From Firmtek: "Every 1x card that I have tested has been limited to 150MB/sec. in actual performance. I understand that in theory a 1x card should support a bandwidth of up to 250 but I have never found that to be true in performance tests. If you require more than 150MB/sec. you will want a 4-port PCIe card for the Mac Pro."
  • Wed, May 14 2008 11:34 PM In reply to
    • rinzeschuurman
    • Amsterdam, The Netherlands
    • Posts 121
    • Points 1,415
    Serleejus:
    Nice find. Though the fact only one sata cable connects it limits the bandwith to a theoretical 150 MB/s in case of sata1 and 300 MB/s in case of sata2 (don't you love all those version... sigh, sometime I long back to the days of the C64) That means that of all the lanes the pci-e card has available, the bandwith of only 2 will actually be used. If you find such device using multilane connections, I'd say we have a winner though.
    Self build soundproofed computercase which also functions and a supporting part of the selfbuild desk/ computer -Quad intel on asus striker extreme board... [view my complete system specs]
    "Software bugs are impossible to detect by anybody except the end user"
  • Wed, May 14 2008 11:38 PM In reply to
    • rinzeschuurman
    • Posts 121
    • Points 1,415
    funckdren:
     Good point! There is a reason the marketing people add theoretical to those statements of available bandwith, cause no company likes a class action lawsuit by angry misled users. Which reminds me of another thing influencing bandwith and data transfer in harddisk raids, block size. I'll add it to the lexicon later.
  • Wed, May 14 2008 11:53 PM In reply to
    • Serleejus
    • Posts 187
    • Points 2,400
    Well.. al this is causing a headache and i now am drinking a well deserved glass of fine merlot...
    Ok.. let's find an affordable HARDWARE raid enclosure with multiple sata 2 connectors.
  • Thu, May 15 2008 12:07 AM In reply to
    • rinzeschuurman
    • Posts 121
    • Points 1,415
    Serleejus:
     Oh, trust me, I was way past headaches and a few crates of mentioned merlot before I found the parts needed to build the solution I chose in the end. And keep in mind the original poster looked for something he could connect with a laptop. I'm not even sure if multilane solutions exist for laptops, or even the posibility to add more then one pci-e card. But I'll have a look.
    Hmm found this and it doesnt bode well...
    http://en.wikipedia.org/wiki/ExpressCard
    Which leads me to the conclusion the only PCI-e card you can connect to a laptop is of the x1 type, allowing you the theoretical speed of 250 MB/s and according to earlier posts the actual speed of 150 MB/s. Still, that's 1300 Mb/s which should be enough for a few layers of compressed HD, if you aren't working with any hardware depending on the same slot.
  • Thu, May 15 2008 12:20 AM In reply to
    • Serleejus
    • Posts 187
    • Points 2,400
    RTX 400-SJ - Hard drive array - 4 ( 4 ) x hot-swap - 3.5 inch x 1/3H - Interfaces: 4 x Serial ATA-300 - Serial ATA-300 - 9.1 Inch
    Ok..here is one by Weibetech, but i am not sure if it is HARDWARE raid... It does have 4 esata connectors though so thoroughput speed shold not be a problem..
    Any Ideas regarding this?
    retails for about $750
    Damon
  • Thu, May 15 2008 12:22 AM In reply to
    • Serleejus
    • Posts 187
    • Points 2,400
    Ok.. it is Harware Capable on PC with the following.
    RAIDable on Windows with 4 port SATA PCI card with hardware RAID capabilities - our part number, PCI-10
    ?? would the tempo esata 4p by sonnet allow hardware raid on PC and OSX?
  • Thu, May 15 2008 12:24 AM In reply to
    • Serleejus
    • Posts 187
    • Points 2,400
    Nevermind... its just JBOD.. not even raid for the above model... I think the merlot is allowing me to have even more "Wishfull Thinking"
  • Thu, May 15 2008 12:25 AM In reply to
    • Serleejus
    • Posts 187
    • Points 2,400
    Meant "Software" raid and JBOD
    RTX400-SJ/RTX400H-SJ -- View specs
    • 4 TrayFree bays
    • 4 eSATA ports
    • Up to 200 MB/s when software RAIDing (About 50 MB/s with each connection)
    • Shock Absorbing Bays
    • Separate key lock for each HDD
    • Upgrade to RTX400H-SJ and get All-Metal Bays!
  • Thu, May 15 2008 12:34 AM In reply to
    • Serleejus
    • Posts 187
    • Points 2,400
    Ok.. i:m done.. I need to call Wiebetech... because apparantly, they offer HARDWARE raid in the products mentioned here, which includes the one i mentioned in a prior post that was also too confusing.
    Here is an explanation from their website.
    WiebeTech offers several products which include hardware RAID controllers.
    RTX
    4 to 8 disk hardware RAID
    many RAID options
    SilverSATA II
    2 disk hardware RAID
    RAID 0 or 1
    RT5x2
    10 disk hardware RAID
    many RAID options
    RT5
    5 disk hardware RAID
    many RAID options
    RAIDTech
    RAID 0 or 1
    Any thoughts Now???
    Hate to say it but HOLY SMOKES
    Damon (i only have time because rendering takes sooo long)
  • Thu, May 15 2008 12:36 AM In reply to
    "Ok.. let's find an affordable HARDWARE raid enclosure with multiple sata 2 connectors"
    Define "affordable".
    Media Composer 3.0 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 4GB RAM, FX 3700, 500GB Boot, 1x1TB & 1x500GB internal SATA media drives (temp), 2xHP L2245w... [view my complete system specs]
  • Thu, May 15 2008 12:46 AM In reply to
    • rinzeschuurman
    • Posts 121
    • Points 1,415
     Well if you aren't afraid of some tinkering by yourself, and have a desktop instead of a laptop, I'd go for this if i were looking to find fast external diskspace at a reasonable price.
    raidcard: about 450$ to 550$ for one of these
    Areca ARC-1120ML (8x SATA300 RAID PCI-X64/133) 256MB Ext.SFF-8088 for pci-x
    Areca ARC-1220ML (8x SATA300 RAID PCI-E x8 256MB) Ext SFF-8088 for pci-e
    case: about 400$ for any case that can hold 8 harddisks, a psu to power the drives and 2 sata-multilane connection brackets
    cables: about 130$ for 2 multilanes and 8 short sata's
    harddisk: 8 sata2 drives at the lowest price per GB currently available, that would be 500GB at about 130$ a piece, totalling 1040$ but prices change fast.
    This will get you 3.5 TB in raid 5 for 2100$, and the cost of a day of your own manhours to build the thing and set it up. But it will be blazingly fast at 350MB/s sustained with redundancy. Compared to other prices I find I'd call it relatively cheap.
  • Thu, May 15 2008 6:28 AM In reply to
    • Serleejus
    • Posts 187
    • Points 2,400
    http://www.3ware.com/products/Ext_serial_ata2-9000.asp
    ok. Finally!! i seem to have found a 4 bay hardware raid enclosure and its affordable.
    this time i am not missing anything
